Step 3Revision: A change inthe shape of the wing
Notice that the angle labeled "Angle A" is 90 degrees. Side A is at a right angle to the diameter line of the rounded end of the wing. In the original design that I presented in this instructable, the two lines forming the pointed end of the were of equal length and their angles to diameter line were identical. That cone was symetrical whereas in the change being shown here, the cone is not symetrical. Making Angle A to be 90 degrees will give the wing more lift
I have resized the design so that I can drive a minigen generator that had been sold at windstuffnow.com (but is no longer available). The basic steps in fabricating the lenz2 are still valid.
Basic Calculation:
I now understand better how to determine the size and proportions of the wing. You first determine what the diameter of lenz2 will be. The easiest way to do this is to decide what the distance will be from the center axis of the lenz2 to the outside edge of a wing. This will be the radius of the lenz2. You double it to get the diameter.
In my new design, I made the assumption that the diameter of lenz2 will be 16 inches (that is, the distance from the center axis to the outside edge of a wing will be 8 inches).
To determine the diameter of the wing, multiply the diameter of the lenz2 times .1875. In my example, 16 inches * .1875 = 3.0 inches.
To determine the length of the wing, multiply the diameter of the lenz2 times .4. In this case, 16 inches * .4 = 6.4 inches. The length of Side A is 6.4 minus 1.5 or 4.9 inches.
I will be creating a new instructable that will include this design in a lenz2 that drives a minigen generator
1/2.618034 = .3819661, 1 - 0.3819661 = 0.618034
I would think the rationale behind this is that the Golden Mean has very interesting self-referential and scale invariant properties. Since air is essentially scale invariant macroscopically at low wind speeds, I would expect the self-referential nature of the Golden Mean to produce a high probability of self-reinforcing aerodynamic behavior. (1/1.618034 = 0.618034, 1.618034^2 = 2.618034, 1/2.618034 = 0.381966 = 1 - 1.618034, etc.)
