Step 5Prepare the end pieces
There will be a notch on each side of the end piece at its widest point. Since this will be on a curve, make sure that depth of each side of the template full fits into the end piece. This will make sure that the rib will be flush with the outside edge of the end piece.
On one side of the end piece near the pointed end draw a pattern that is about one inch from point. The rectangle will be parallel to the slanted side. The side with two notches will the back side of the wing (the side that faces the center of the turbine.)
Cut out the notches with a jigsaw.
comment
Add Comment
Add Comment
