Leopard Gecko Care
Introduction: Leopard Gecko Care
I will show you how to take care of a Leopard Gecko.
Step 1: Gather Materials
You will need:
Leo Gecko
Terrarium (10+ Gallons)
Dome Light Fixtures
Bulbs (About 4)
Reptile Hide
Water Dish
Reptile Carpet
Temp/Humidity Gauge
Food (Crickets, Mealworms, etc.)
Cricket Carrier
Food for Insects
Decorations (Optional)
Calcium Dust/Supplement
Step 2: Terrarium
Before you buy a Gecko, you need a terrarium. A good size for a Leo is 10-20 Gallons. You will need substrate. I recommend reptile carpet because its easy to clean and lasts long. You will need a hide big enough for your leo to hide in. For a water dish, a small, shallow pool will suffice. You can decorate with rocks and cacti. You will need a temp/humidity gauge to make sure the terrarium is right temperature and humidity. Temp.: 80-95 Degrees/Humidity: 20-40 Percent
Step 3: Lighting
I use heat bulbs instead of a heating pad, so lighting is important. I recommend a Zilla Night Heat bulb (night heat/viewing), Zilla Daytime bulb (light/some heat), Zoo Med Basking Bulb (day heat), and Exo Terra UVB bulb (calcium UV rays). You should use 2-4 reptile light domes for these (porcelain base)
Step 4: Food and Nuitrition
Giving your gecko correct food will help it grow strong. Crickets, mealworms, superworms, etc. all are good choices, but be sure to dust with calcium. You will need a cricket carrier or similar to contain them. Make sure you feed them.
Step 5: Finished
This is how you take care of your Leo Gecko so it's happy and healthy.
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
    sorry that posted when it wasn't meant to soi hi I am looking for a leopard gecko for sale any help?
    I have geckos and don't u need calcium
    The basking bulb provides heat for my gecko to digest the food, it keeps the temperature 85 Degrees in the hot side of her aquarium
    The 2 bulbs, basking and UVB are useless for leopard geckos as they are a nocturnal species and will not obtain the benefit from the use of them.
    kitchen roll works well as a base for the terrarium too, crickets can be fed vegetable chunks (I tend to chuck a few mushrooms in with mine) make sure there is a heat gradient in the terrarium so your gecko can go to the temperature they want. your gecko is gorgeous. from a fellow geckophile. also make sure the water is in the cold end of the terrarium.
