Daily Driver E-Bike
2,109
26
4
Published
Introduction: Daily Driver E-Bike
About: I am Undergrad Electrical Engineering student who is DIY enthusiast and like to share information.
My Goal is to convert a $99 bike to e-bike with a budget less than $700 and use my bike as my daily driver.
Since I am focusing on battery life cycle, I want it to last much longer as possible. I am using BMS(Battery Management system) and a charger that was able to charge the battery at 80%.
Any suggestions and comments are welcome.
Thanks
IK
Step 1: Parts Needed
Step 2: Battery Design
The battery I am using is Samsung 25R 18650 2500mAh 20A Battery
Specs (I got from IMR.COM)
  • Nominal Capacity: 2500mAh
  • Nominal Voltage: 3.6V
  • Protected: NO, UNPROTECTED
  • Dimensions: 18.22mm x 64.80mm
Weight: 43.71g
My Motor
  • Voltage: 48V
  • Power: 1000W
I need at least a battery pack that supply 48V. I decided to go with 52V setup. 14S and 5P.
In Theory, I am getting
3.6v*14s= 50.4V
2.5Ah*5p=12.5Ah
and single 18650 has 3.6V*2.5Ah=9Wh. Therefore my overall Watt Hour will be:
Watt hour =Amp hours of cell *nominal voltage of the cell
Wh = 50.4V*12.5Ah=630Wh
Step 3:
Step 4: The Overall Design
Step 5:
Step 6: Testing the BIke
Step 7: To Be Continued...
    • Planter Challenge
      Planter Challenge
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    4 Comments
    i;m also thinking of doing the same project ,don't forget the dangers of li-ion batts . i think protection is needed ,and once made i thought of filling it with oil to keep them evenly cooled when charging and also in use ,and away of hiding the cables around the frame .just an idea what about super capacitors could be more money
    Thanks for your feedback. I will take that into consideration. Also I will try to place high power cable on one side and low power on the other side.
    Thanks! I will post a video and more information once I build 18650 Cells :)
