Let`s Make a Metallophone.
2,679
56
Published
Introduction: Let`s Make a Metallophone.
A metallophone is any musical instrument consisting of tuned metal bars which are struck to make sound, usually with a mallet.
You will need:
  • wood (1) 32cm x 2x1,5
  • wood (2) 60cm x 2x3,5
  • metal bar 2m x 3cm x 4mm
  • screws 16mm x 3mm
  • flat washers
  • 4 screws 5cm
  • 1 wood varnish gloss
Step 1: Metal Bars
Cut the metal bar in 8 tracks from 15cm max-10cm min.
Cut the metal bars slightly awry about 1-2 moires to form all together a triangle.
Open holes with a drill.
Step 2: Wood
Cut the wood (1) in 2pcs 14cm and 17cm.
Cut the wood (2) in 2pcs 30cm and 30cm.
Step 3: Fitting Metallophone
  1. First count the metal bars to have equal distances.
  2. Then let's screw the screws onto the wood.
  3. Screwed 4 bigger (5cm) screws to side wood (2) to complete the fitting.
Step 4: Paint the Metal Bars
  1. Remove the screws.
  2. Paint the metal bars with colors we want.
  3. When it's dry. Screwing the metal bars in wood.
  4. Put and the flat washers (wood-->flat washer-->metal bar-->screw).
  5. Spray the metallophone with the wood varnish gloss.
Enjoy your metallophone
    • Casting Contest
      Casting Contest
    • Planter Challenge
      Planter Challenge
    • Stick It! Contest
      Stick It! Contest
    3 Comments
    Simple but cool, voted.
    nvm I just learned a metallophone is the metal version of a xylophone.
