Letter Opener from a Used Club Card by StumpChunkman
I open up a lot of mail at the office!  Normally when a new package comes in, I'll break out the box cutters and cut what I need to get it open.  When it's all said and done, I've occasionally cut what's inside the box.  This isn't an option I want when I'm opening up unknown things.
I've seen letter openers in stores for years, but I never felt like dropping the money to get one.  When I recently came into possession of some extra stock of Duane Reade club cards, I knew I had my chance!
Step 1: Materials
Club card, credit card, gift card, or other no longer useful plastic card.
Laser Cutter, X-Acto knife or Scissors.
X-Acto blade
Tape
Pliers
A few minutes to spare.
Step 2: Template
Designing this is very simple.  If you look up some images of letter openers, there are two predominant styles.  The mini sword/knife and the plastic card.  Since the plastic card style works so well with our plastic card, I'm going to use that one.
One thing I learned while making these, having a long skinny edge doesn't work. I find that a short, thin at the end point, works best - see pictures for more details.
Draw a template on your card, or in whatever program you plan to use to laser cut with.
If you're using the laser cutter, I'd recommend creating a template for the card that you can use to ensure you have it situated in the correct space when you laser etch.  You can use cardboard or some scrap acrylic for this purpose.
Step 3: Cut
Cut out your template with an X-Acto blade or laser cutter.
Step 4: Prep X-Acto Blade
First: PUT ON EYE PROTECTION!  Should accidents happen you don't want exposed eyes with X-Acto blades flying about.
  • Grab the X-Acto blade firmly between two pairs of pliers.
  • Slowly bend the X-Acto blade in half.
  • You should have half of the X-Acto blade in each pair of pliers when it snaps (it doesn't take much bend to snap it).
Step 5: Attach Blade
Now that you have a smaller blade it can fit onto your letter opener.
Grab some clear tape, and tape the X-Acto blade in place.
If you're worried that someone might cut themselves, grab another card and sandwich the X-Acto blade between them.
Step 6: Finished!
Now take your new creation and run out to the mailbox.  Sit in anticipation for when the mailman comes and proceed to open your mail with a sense of ease you haven't experienced in years!
lemonie says: Jan 19, 2010. 1:05 PM
Will it do those tough plastic straps you get on boxes of paper (I forget what they're called and am not going to look them up right now)?
L
axlotleft says: Jan 21, 2010. 9:32 AM
If you flip those straps over and find the spot where they are joined, there will be a little bit of the end of the underside strap sticking up. If you grab that tab and pull it back, the layers separate and the strap comes undone. No tools needed.
lemonie says: Jan 21, 2010. 12:11 PM
Yea, that's what I said a bit further down the page. Did you see the response to that? It seems some people make these extra-hard to open.
L
StumpChunkman (author) says: Jan 20, 2010. 8:22 AM
I haven't tried that, as I don't get many boxes with those straps.  I'd have to agree with valhallas_end though, and I don't think I'm ever going to actually try.
lemonie says: Jan 21, 2010. 12:12 PM
The look is pretty much exactly like purpose-built strap-cutters, I only asked because of that and the questionable sturdiness.
L
valhallas_end says: Jan 19, 2010. 3:24 PM
Whatever those are called, they destroy razors' and box cutters' blades, so I can't imagine an X-Acto surviving very long - the fibers in the plastic dull and pit the blade quickly.  The straps that bind rugs and large furniture boxes are even worse (generally sharp yellow plastic glued together with an epoxy to rival a weld).  For all of the plastic straps, I'd suggest having a second design with an open blade or one that can slice across the plastic, not cut through it - parting the strap is a lot easier with repeated slices than a straight cut.
I have also wrecked steak knives on those straps...they can catch and bend serrated edges.
lemonie says: Jan 19, 2010. 11:56 PM
The easy way is to simply pull apart the thermal join. It's super strong in tension, but rather weak to that kind of shear. Like peeling off tape.
L
valhallas_end says: Jan 20, 2010. 6:43 AM
Very true, but most of the packages I receive have the join stepped inside the box and the holes taped over or sealed (I guess it's a security system my local distributors insist on?  I can see some merit - far harder to open the package without leaving some telltale from the tape).  It's a bit harder to access to pry apart.  Luckily, I have a trail knife designed for cutting fibrous bamboo and vines which works very well.
lemonie says: Jan 20, 2010. 12:22 PM
That is being careful... these are valuable consignments?
L
valhallas_end says: Jan 20, 2010. 6:19 PM
Some are valuable - I've been trying my hand at creating audio equipment (starting with guitar amplifiers, speaker cabinets, and electric guitars), and some pieces must be bought in bulk for fully custom builds.  They have to be wrapped as tight as possible, so these straps are ideal around the inner cardboard box.  Believe me, you do not want a "DOA" shipment of mahogany.
I have noticed some paper boxes my local Staples receives have this system too, and for their office furniture.  I know my local warehouses have a severe theft problem, so maybe its a modification added in situ.
loppy96 says: Jan 19, 2010. 3:59 PM
why does everyone have these dwuane read cards
Gadget Gangster says: Jan 19, 2010. 11:22 PM
Duane Reade is doing an advertising program with instructables (read canida's comment).
I guess they're east coast only, though - I'm in CA and never heard of 'em.
valhallas_end says: Jan 19, 2010. 3:18 PM
Huh, I've lived in NY all my life and never heard of this Duane Reade...
This is a nice solution though - I tend to ignore my box cutter in favor of a trail knife, but have sliced into books before.  Maybe this would help...
Doctor What says: Jan 19, 2010. 12:58 PM
 I've seen these in buses too!  They're used to cut seatbelts during emergencies.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
