This instructable has been removed by the author.
34
comments
Add Comment
Aug 1, 2010. 1:30 PMjtong77
says:
Great video!! I'm gonna try it. Just out of curiosity, is your voiced processed?
Aug 1, 2010. 4:58 PMM4industries
says:
Yes... well sort of... he records his voiceover and alters it to prevent Feds from tracking his voice using recognition software.
i honestly did not expect the voice to garner that level of mockery.
Nov 24, 2010. 2:03 PMDIY-Guy
says:
NurdRage- I think this whole presentation is very creative, well done!
(But did you appreciate the joke?) :)
Jul 30, 2010. 4:02 PMhifatpeople
says:
magnet roads, specially designed pencil lead like cars, i see the future
Sep 12, 2010. 5:58 PM8v92
says:
If thicker pencil lead wont work then there must be a surface area effect going on , maybe some thin films like plastic might work.
Sep 4, 2010. 1:11 PMdwzavaleta
says:
Was wondering how to levitate an array of these leads - maybe gluing several parallel, but separate, to a thin tissue of some sort. how would the fields of leads in the array interact?
Aug 17, 2010. 9:18 PMubr.bzkr
says:
So what specific brand(s) of pencil lead have worked for you and which ones defiantly don't?
Jul 30, 2010. 6:34 PMhunter1125
says:
I also saw this levatating magnet in Simon Queenfield's book Gonzo Gizmos
Aug 8, 2010. 11:22 PMelenwaren
says:
i have lean to the vitate apencil lead good job and have a niice day
Aug 2, 2010. 7:53 AMtoelle
says:
Tried this with 8 1cm. diameter neodymium magnets and a piece of 0.3mm. pencil lead. It seems to work but the levitation is very very small. Less than 1 mm. Will try it in water next.
Jul 29, 2010. 7:30 PMREA
says:
also works with beryllium, bismuth, carbon, copper, mercury, silver, and zinc.
Jul 29, 2010. 9:42 PMREA
says:
sorry, i havent tried. its just that those are all the diamagnetic elements, so i just assume they would work. i thought i had seen a picture of bismuth, but i forgot where.
oh i see. It doesn't work with all diamagnetic elements. because the effect has to overcome the mass of the object. But since all of those elements have different densities, and thus masses for equal volumes, most of them won't work. You need REALLY powerful magnets to get them going. Pencil lead and neodymium magnets are the easiest to get things that this has a visible effect on.
Jul 30, 2010. 12:33 PMwolfkeeper
says:
Levitation of a magnet can be done with all of these materials. I've even seen it done with fingers, fingers are mostly water, and water is diamagnetic. You have to use another magnet to counteract most of the weight though.
Jul 29, 2010. 11:35 PMREA
says:
that does make sence. that explains why all the diamagnet images on google had large electromagnets.
Jul 30, 2010. 6:31 PMhunter1125
says:
Modern pencils contain graphite. Thin graphite surfaces can levatate above magnets. Try getting thin graphite squares from a home depot or lowes because I am pretty sure they have them.
Jul 30, 2010. 8:56 AMDarmani
says:
Hi, cool i have watched youre videos in youtube for some time now, i didnt know you had an account on Instructables, hehe cool videos, i like chemestry but im just an amateur.... keep up the good work.
Jul 30, 2010. 1:57 AMwestfw
says:
This little device http://www.kjmagnetics.com/proddetail.asp?prod=LEV2 works pretty nicely. It uses the more traditional technique of suspending a magnet between sheets of graphite, with another magnet "helping" to counteract the weight. Interesting that pencil leads can have the appropriate type of graphite...
I always wondered why that happened... Thanks for the explanation.
Jul 29, 2010. 3:11 PMRe-design
says:
Very cool! I was going to see how you were faking it but ITS REAL!
This is a 'must try' experiment !
You've used an HB lead. It's probably worth trying with a 2B (softer - higher graphite content) to see if it levitates higher.
Awesome demonstration! Newly, thanks for the captions in the video.
