loading
video How to Creatively Use a Levitron for Magnetism Demonstrations
The Levitron spins and surfs on magnetic waves! Pass your hand above, underneath, and around the top. It will continue to spin and float only touching air! The LEVITRON floats free in space, supported only by the repelling magnetic force produced by permanent magnets.
i am just a beginner..i have a doubt..
will it work if i rotate the base magnet (the one below using motor or smthing) and leave the small (levitating magnet) stationary.. will the small magnet levitate??
armando90993 years ago
MM hey one question... Can the temperature variations affect?
kyleboy19937 years ago
if you put it in a complete vacuum it should keep going because there would be no friction.
that would be sweet. but the vacuum couldn't take all of the stuff out so it would have to stop at some point.
well, yeah, but if it was a complete vacuum like kyleboy1993 was saying, it wouldn't. Sadly, we don't really know how to make a complete vacuum...
What if you used a non-material container that wasn't magnetism.can they create a perfect vacuum and can they exist without magnets?
Maybe with big friggin' lasers?
Algag netgrazer5 years ago
 non material container? like antimatter!!?? XD
Well a perfect vacuum is COMPLETELY impossible. Even the deepest of deep space still has about one atom per meter. But the chances of the top hitting that atom are so small, your great times 8* grandchildren would be dead before it would even begin to slow noticeably. * Hyperbole, but still could be true
see even that one atom per meter would be nearly impossible ... for example with one atom per meter i could just walk in there with a box take off the lid and put it back on and the chance of me hitting that one atom in that whole meter btw do you mean meters cubed or what cause technically there are 0 atoms in a meter
The reason a perfect vacuum is impossible is that even if you could remove that one atom per cubic meter, space is still filled with virtual particles. These particles, and their anti-matter counterparts flash into and out of existence constantly (but always add up to 0, which is why they don't violate the 2nd law of thermodynamics). They can't be removed from space since they are an inherent characteristic of space. The contribute enough 'pressure' to keep us from obtaining a perfect vacuum.
Even if you had a perfect vacuum there would still be loss of energy due to radiation. which would come about simply because there is a moving electrical charge (i.e. the magnet, as even permanent magnets are magnetic due to the spin of an electron). Also their is the zero energy problem stated above (i.e. total vacuums have a spaced energy levels that cause spontaneous radiation/creation& annihilation of particles.)
No, even a complete vacuum will not work, for a lot of the tops energy wiil be lost to the vibrations of the smallest defects
TOCO6 years ago
There is a product by the manufacture that allows it to constantly run as long as the power doesnt go away for more than about 4 minutes. It is called the perpetuator. just go to http://fascinations.com/unique-toys-gifts/levitron-accessories.htm .
JAKEjones17 years ago
that is so freeking sweet! where do you get one of those? please reply i collect wierd things like you do and i want to add this to my collection! please reply!
just google levitron :D
innovatoys sells them for thirty dollars.
you buy them off the internet, at science stores, etc. it's called a levitron.
tanmanknex6 years ago
I love the ending part! this isn't really an instructable as much as a how does it work thing... it's still great!!!
TOCO6 years ago
what weights did you use? what weights did you use? what weights did you use?
reido6 years ago
It would be fun to make a big slow spinning one with a laser pointer on it and let it rip inside a room full of cats... Just need to figure out a way to harness the cat power!
its called.... i have no idea..i call dibs on the invention whoever makes! lol
so how did it taste? lol
sotsirh1947 years ago
That's funny I have the exact same floater at the beginning of the video that was in the bottom left hand corner.
duct tape7 years ago
lol, he ate it!
casey321b7 years ago
I like the one where he uses a beaker. that is cool!!!
joey25426677 years ago
that was on mythbusters!
PKM7 years ago
I was so impressed with this science toy that I googled it to find out where I could get one.. and found this text on the Levitron product homepage: "Spin the top - and watch it float! The Levitron spins and surfs on magnetic waves! Pass your hand above, underneath, and around the top. It will continue to spin and float only touching air! The LEVITRON floats free in space, supported only by the repelling magnetic force produced by permanent magnets" You get a - for blatant product advertising with no real Instructable content.
Shifrin7 years ago
the last one was great!
Nice! Did you make that thing?
no its a levitron that youtcan buy of line $29.95 hey thats not that bad for something like this go here: http://www.innovatoys.com/p/LEV/LEV20
