3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Lexan Computer Case
Lexan Computer Case
Build your own clear computer case out of wood and lexan. I started this project intending to build only a simple box, but ended up going all the way for this complete case build. Without the light it cost roughly $30 dollars and, although time consuming, was well worth the effort.
Step 1Assemble Materials
Assemble Materials
For this project, you will need:
2x 1.5' by 2 sheets of 1/8" lexan. You can find these at Lowes or hardware stores, they run for about $6. I only actually used two, but you may want to purchase an extra, as they can break if you're not careful. Make sure that what you're purchasing is actually lexan and not acryllic, as acryllic will shatter way too easily. If you look at the edge it should be dark for lexan and almost white for acryllic.
4 feet of 1" by 2" pine or other wood for vertical supports
1 18" by 20" piece of plywood or press-board (which is cheaper)
1 8" by 18" piece of plywood/press-board
1/4 20 bolts and nuts
Punched 1 1/4" aluminum for drive bays; ~10" per 5 1/2" drive
2 31" strips of punched aluminum for drive bay mounts (If you want, you can substitute two more wood verticals, which will save you a lot of bending and having to align the holes in the aluminum)
Punched 1/2" aluminum angle for 3.5" drive bays; 4" per drive
Velcro (lots of it), preferably matching whatever color you want to paint the wooden parts
Spray paint
And the following tools:
Jig saw with fine toothed blade or fine toothed craft (model making) saw
Drill with 1/4" bit and a bit large enough to accommodate your saw blade
Circular saw (to cut plywood)
Sharpie marker
Hammer
Hacksaw
Dish soap and WD-40 (to lubricate and cool hacksaw blade)
25 comments
Aug 29, 2011. 2:27 AMR.A.T.M says:
lots and lots and lots of dust that the prob with my custom i have a black lite neon all clear el wier lighted computer with water cooling (coverd with el wier and neon paint) and air cooled i have some probs with lots of dust getting in to it it gets hot in it so i do not want it to blow not after all the $ and time spent in making it
Feb 15, 2011. 1:39 PMRoninVj says:
you should try bottom mounted power supplies. its less work . >.-
Feb 28, 2011. 6:17 PMcoreyjune12 says:
That's exactly what I was thinking.
Dec 28, 2009. 6:26 PMrastaman108037 says:
What magic Lowes department store did you find 1.5' x 2' Lexan sheets for $6? When I looked it was upwards from $30. It sounds like you have Lucite (plexiglass).
Jul 9, 2009. 4:28 PMFagnerFS says:
Hey, very good project! but, it looks hard to do.
Mar 21, 2009. 4:28 PMN1CK4ND0 says:
Lol this is exactly what im doing right now, I have the base of plexiglass, and my mobo is mounted, just need to attatch the sides and top.
Jan 21, 2009. 11:31 AMcotton says:
no offence your cuting job to accces the cdrom is horrible but the paint job is super amazing
Jan 4, 2009. 7:39 PMGjdj3 says:
Dang! That's so awesome! I want to build my own desktop, so this would really be something I might do. 5 stars and favorited.
Jan 4, 2009. 3:48 PMI HACK says:
this is a verry good idea , good job, but in some ways i find it to be verry sloppy.
Feb 18, 2008. 6:41 PMuberinsane says:
I am concerned that the parts would not be as secure or strong as in a traditional $40 prebuilt case.
Feb 4, 2008. 4:58 PMJazzmanSA80 says:
Thanks for this. I've been thinking about building my own case for my rig for some time now but I wasn't sure if I would get myself into more than I felt like doing. It's encouraging to see to see someone else's work before I dig in!
Jul 31, 2007. 8:25 PMfrazeeg says:
I believe they make a Lexan glue that actually fuses the edges together, something like this. Instead of using the velcro, (which you might have added for easy of disassembly, which is fine) the adhesive/solvent practically welds the sheets together, giving you a nice clean look.
I've actually been throwing this idea around in my head thinking of the best way to go about it. I'll definitely take your tutorial into consideration when I finally do build it. Thanks.
Aug 1, 2007. 4:34 PMfrazeeg says:
I'd try 1/4" Lexan. It's a bit more expensive, of course, but in your case it would be worth it. You could even do away with the ugly particle board backer :-P
Apr 1, 2007. 1:18 PMphoenix124 says:
Nice instructable. i like all the effort u put in, totally commendable! u should join my group: http://www.instructables.com/group/modthis/
happy modding
Mar 9, 2007. 9:48 AMglyph says:
Nice Job. A few suggestions for a smoother outcome. Instead of the particle board you are using, you might purchase something like a furniture grade ply product. I would use sandeply - available at Home Depot. Sandeply is more capable of a fine finish and takes primer and paint well. You might also consider the use of aluminum channel stock to make a slide out tray for the hard drive and the CD/DVD servomechanism. The suggestion for auto edge trimming on external edges has already been made and it's a good one. To truly finish the edges of the lexan, you should make a sander by drilling a hole in a block of wood, split the block into 2 parts, and glue a 400 grit sandpaper and a 220 grit sandpaper onto each half - make a handy "half-moon" edge finisher. Cut the hole big enough to handle your lexan - 1/4 lexan will require a 3/8 hole. Those nice, polished lexan edges will absorb and channel light for very cool effects. The final frosting is learning to mask the backside of the lexan and paint the inside of the case - the results are a shiny exterior paint that won't foul off which you're moving the computer around. Can't wait to see the refinement! Good Job!
Mar 6, 2007. 11:46 PMFake_Name says:
It looks like all your "aluminium" is actually galvanised steel. Grab a magnet and check it. I'd bet it's ferrous. While you're at it, paint that chipboard.
Mar 7, 2007. 9:44 AMHamO says:
A big A+ for effort. Nice instructable. Nice photos. I might suggest auto door edge trimming for the rough edges. It comes in a variety of colors and is easy to work with.
Mar 5, 2007. 2:48 PMbrianf25 says:
good idea. A bit rough, but still looks cool. nice job.
Mar 6, 2007. 12:10 AMbrianf25 says:
Lexan is hard to work with if you dont have the propper tools. Maybe you can get some sort of edging material to cover up the rough cuts. Another thing i would do is maybe spray paint that particle board black so its not as visible
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Raistillian
