loading
Step 7: Mount the power supply
Now we have to mount the supports for the power supply. This is also quite simple, as you can figure out the placements pretty much by just sticking in your power supply and tracing it out. The rearmost bracket should attach to the rear vertical, and the forward bracket to the side panel. It helps to place them as far apart as possible, but make sure the wire's from the power supply don't get in the way.
lots and lots and lots of dust that the prob with my custom i have a black lite neon all clear el wier lighted computer with water cooling (coverd with el wier and neon paint) and air cooled i have some probs with lots of dust getting in to it it gets hot in it so i do not want it to blow not after all the $ and time spent in making it
you should try bottom mounted power supplies. its less work . >.-
That's exactly what I was thinking.
What magic Lowes department store did you find 1.5' x 2' Lexan sheets for $6? When I looked it was upwards from $30. It sounds like you have Lucite (plexiglass).<br />
Hey, very good project! but, it looks hard to do.
Lol this is exactly what im doing right now, I have the base of plexiglass, and my mobo is mounted, just need to attatch the sides and top.
no offence your cuting job to accces the cdrom is horrible but the paint job is super amazing
Dang! That's so awesome! I want to build my own desktop, so this would really be something I might do. 5 stars and favorited.
this is a verry good idea , good job, but in some ways i find it to be verry sloppy.
I am concerned that the parts would not be as secure or strong as in a traditional $40 prebuilt case.
Well, it's not a professionally made case, but that's the whole point. A prebuilt lexan case would cost a lot more than $40.
Thanks for this. I've been thinking about building my own case for my rig for some time now but I wasn't sure if I would get myself into more than I felt like doing. It's encouraging to see to see someone else's work before I dig in!
I believe they make a Lexan glue that actually fuses the edges together, something like <a rel="nofollow" href="http://www.rplastics.com/weldon4.html">this</a>. Instead of using the velcro, (which you might have added for easy of disassembly, which is fine) the adhesive/solvent practically welds the sheets together, giving you a nice clean look.<br/><br/>I've actually been throwing this idea around in my head thinking of the best way to go about it. I'll definitely take your tutorial into consideration when I finally do build it. Thanks.<br/>
That sounds pretty cool, I'll have to look into it. Part of my problem was how thin the lexan I used was, so I needed the wooden frame to support it. If you had a piece thick enough, you could probably use that to make the entire thing transparent..
I'd try 1/4" Lexan. It's a bit more expensive, of course, but in your case it would be worth it. You could even do away with the ugly particle board backer :-P
Nice instructable. i like all the effort u put in, totally commendable! u should join my group: <a href="http://www.instructables.com/group/modthis/">http://www.instructables.com/group/modthis/</a><br/>happy modding<br/>
Nice Job. A few suggestions for a smoother outcome. Instead of the particle board you are using, you might purchase something like a furniture grade ply product. I would use sandeply - available at Home Depot. Sandeply is more capable of a fine finish and takes primer and paint well. You might also consider the use of aluminum channel stock to make a slide out tray for the hard drive and the CD/DVD servomechanism. The suggestion for auto edge trimming on external edges has already been made and it's a good one. To truly finish the edges of the lexan, you should make a sander by drilling a hole in a block of wood, split the block into 2 parts, and glue a 400 grit sandpaper and a 220 grit sandpaper onto each half - make a handy &quot;half-moon&quot; edge finisher. Cut the hole big enough to handle your lexan - 1/4 lexan will require a 3/8 hole. Those nice, polished lexan edges will absorb and channel light for very cool effects. The final frosting is learning to mask the backside of the lexan and paint the <em>inside</em> of the case - the results are a shiny exterior paint that won't foul off which you're moving the computer around. Can't wait to see the refinement! Good Job!<br/>
Thanks. I know the particle board wasn't the best choice for aesthetics, I simply chose it since I had it lying around, and it's dirt cheap. The idea of slide out drive bays sounds cool, I'll have to look into that. The sanding block idea sounds cool, I think I'll try that, and I'll add it to the Finishing Touches step if I end up doing it. As for painting the backsides of the lexan, I tried this on some test pieces, and it did come out nice looking, like the black iPods. However, I still want the clear look, so I think I'll stick with that. Thanks for the suggestions though. =)<br/>
It looks like all your "aluminium" is actually galvanised steel. Grab a magnet and check it. I'd bet it's ferrous. While you're at it, paint that chipboard.
You were right, it is steel. And I painted the foam board and particle board, with an updated picture.
A big A+ for effort. Nice instructable. Nice photos. I might suggest auto door edge trimming for the rough edges. It comes in a variety of colors and is easy to work with.
good idea. A bit rough, but still looks cool. nice job.
Thanks, I have to do it again someday having learned what I know now. As you can see the front plate cracked a little while I was cutting it, and the top bay is still rough around the edges. I don't feel up to making if for a fourth time just yet though =)<br/>
Lexan is hard to work with if you dont have the propper tools. Maybe you can get some sort of edging material to cover up the rough cuts. Another thing i would do is maybe spray paint that particle board black so its not as visible
Yeah, the cuts I'm still planning on filing down, which works pretty well. Painting the particle board is definitely something i still have to do, it's still sort of a work in progress.
About This Instructable
57,661views
77favorites
License:
More by Raistillian:Lexan Computer Case
Add instructable to:
