3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Li-Ion Battery capacity tester (Lithium power tester)
  • last photo ←
=========== WARNING & DISCLAIMER ==========
Li-Ion batteries are very dangerous if not handled properly .
DO NOT OVER CHARGE / BURN / OPEN Li-Ion Bats
Anything you do with this information is your own risk
Build a Li-Ion battery tester
I have so many old lap-top batteries around and some work better then others but I really wanted a way to measure each battery exact capacity and couldn't find anything on the web so I took the time (2 hours) and built my own.
Now I am sharing it with you all.
Enjoy
(The guy in the airport thought it was a bomb - wonder why...)
Step 1Operating instruction
The basic operating principle is :
1. Set the clock to 12:00
2. Connect the battery to be tested (polarity is important)
3. Press the push-switch once
4. The two LEDS will turn on and the watch will start working .
5. After the LEDs turn off - check the watch reading and multiply it by 0.38 , that will give you the amount of Amp/Hour you have in this battery .
26 comments
May 18, 2009. 6:07 AMbugmenot says:
Can you clean up the circuit layout? Is the emitter on +? N.C. probably does not need to be connected? Cheers!
Mar 22, 2012. 5:31 AMrrungano says:
can you please send me a corrected version of your circuit diagram,the area on the relay and the value of the relay are not clear to me.i want to build mine soon.
thanks
reuben
May 16, 2009. 6:36 AMHammerhead46 says:
I will be building one of these today so I can test the 10 batteries I have around here.
GREAT work, keep it up.
My thanks to you.
Mar 19, 2012. 1:58 AMrrungano says:
please can you help,the connections around the relay are not clear for me.if i connect the emmiter to the NO,what happens to the NC,can you post me a corrected version of the circuit please. reuben
Nov 25, 2011. 11:14 AMjbaker22 says:
So, will this show me how to get the most amperage out of a Li ion battery?
Nov 25, 2011. 11:22 AMjbaker22 says:
Cell phone batteries can't put amps out like other batteries.
May 15, 2010. 1:26 PMscratchr says:
lithium ion batteries when totally discharged are destroyed.
Sep 20, 2009. 7:45 PMjerkey says:
This is great! I am a big fan of the simple low-voltage disconnect, using the LED and the bipolar transistor is beautiful. Thank you for making this instructable. I recommend you download the Gimp, which is a free image-editing program like photoshop, and it will take just a minute to edit your schematic. And it's fun.
Jun 5, 2009. 9:30 PMG.O. Bluth says:
Before you go home and crack those old laptop batteries open listen up for your own safety - I test these for a living. Lithium Ion Batteries can be really dangerous. Be EXTRA Careful when working with Lithium Ion Batteries. Traditional Lithium Ion Batteries contain Cobalt Oxide - which is very flammable - enough to really ruin your day. All Lithium Ion Batteries can produce Hydrofluoric acid when the electrolyte is mixed with water in the right proportions. Hydrofluoric Acid will liquefy your bones, and kill you. It is not treatable. NEVER put more volts into a battery than the nominal rating. Charging a lithium ion battery with more voltage is not going to make the battery charge faster, it is going to make the battery blow up, venting electrolyte gas at the very least. To make a battery charge faster - supply more current. If your battery says "3.3V 1.3Ah" this means that the battery can supply 1.3A for 1 hour. When charging the battery, supply 3.3V 1.3A - this will cause the battery to fully charge in 1 hour. 3.3V 3.9A (3C rate) will cause the battery to charge in 1/3 of 1 hour. There is a limit to how much current you can charge with. Refer to lierature from the Manufacture of the battery cell for charge/discharge. Do not exceed the manufacturers specfications. It is not a good idea to solder to the cell. Good Luck. Be Safe.
Jul 7, 2009. 10:19 PMlolzertank says:
I guess I'll add some more... Lithium batteries are NOT charged to their nominal voltage. In the case of Lithium Cobalt cells, they are charged to 4.1 or 4.2V, not 3.7V. If you don't believe me, Google is a great friend. 4.1V helps the cycle life of the cell while 4.2V gets you about 10% more capacity. Some old cells can't take 4.2V though, so if you're unsure, charging to 4.1V is a better choice. Also, for Lithium Cobalt, NEVER charge faster than at a 1 hour rate. I think some manufacturers list the absolute maximum charge rate at 2C, but that is pretty dangerous with normal Lithium Ion cells. A toxic fire isn't too fun. Another thing to beware of are short circuits. Short circuiting a lithium ion cell is VERY, VERY dangerous, many times resulting in venting and sometimes explosion of the cell. Don't over discharge the cells either, I think 3V is the discharge threshold. Over discharging isn't really unsafe since there's no energy in the cell for it to explode, but over discharging does damage the cell. Recycle these cells since they could blow up the next time they're charged. A protection circuit is a good idea when using lithium ion cells, as it would negate most of these problems. Be safe, this can be dangerous.
Jun 10, 2009. 10:09 AMblackbeardlion says:
very steampunk-esk! excellent instructable!
Jun 7, 2009. 10:29 PMtannerr52 says:
don't take this to the airport... : /
Jun 2, 2009. 3:14 AMeightdot says:
I think the Emiter should be connected to NO and not NC.. otherwise the holding function doesn't work.. and i advice to add a series resistor for the white led
May 27, 2009. 5:17 AMjames.mcglashan says:
have or had in that battery
May 16, 2009. 7:27 AMTetrafluoroethane says:
Did you take into account the current through the current through the LEDs and relay when arriving at the 0.38 figure? I am assuming so since calculations on the 9.4ohms of resistance you used come up with closer to 0.399. What made you decide to use 9.4 ohms as the load instead of something that would multiply a bit easier? Like ~37.5ohms or ~3.7ohms making the current draw ~100mA or ~1A?
May 18, 2009. 9:43 PMappsman says:
This is very cute. There is an appnote in the link for a similar circuit with an adjustable end-of-life point that was written in 2002. That one used a drugstore AA-powered alarm clock which might be easier to work with than a watch.http://www.maxim-ic.com/appnotes.cfm/an_pk/527
May 16, 2009. 10:37 AMeight says:
Very nice idea and implementation. Thanks for your Instructible !
May 15, 2009. 1:28 PMhg341 says:
wel know i never thouogh on that
use a clock to test your bats....
May 15, 2009. 3:52 AMgip_mad says:
Very interesting approach! Keep up the good work :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
28
Author:moris_zen
