In September, 2010, I volunteered to build a float for a Halloween parade. The theme of the float was patriotic / historical, incorporating historical US flags and a replica of the Liberty Bell. For some time I had wanted to experiment with sculpting with extruded polystyrene (XPS) foam, so this project afforded the oppurtunity to consume scraps of 2" material had saved from my insulating-the-workshop project. At the time I built the replica, I wanted to encase it in fiberglass-reinforced polyester (FRP), but time did not permit. That had to wait until later.
I knew that I could deal with the vulnerable nature of the paper maché and joint compound exterior skin for one parade event. Unfortunately, over the subsequent months, handling and storage of the bell revealed that refinishing with FRP would be necessary and inevitable if I were to keep the bell useful. When I finally found the time to do this, it did not occur to me to take photos of the process. This was partially due to my fear of the resin setting before I was finished working with it (I generally don’t have an assistant). I also did not document making the crown, mounting hardware, yolk, supporting frame, and road case.
Step 1: Materials and Tools
A. Tools
1. Utility knife
2. Wood file/rasp
3. Small hand saw
4. Bar compass
5. Metal straight edges/rulers
B. Materials
1. White glue (I prefer Elmer's)
2. Rubber cement
3. Spray adhesive (I prefer 3M 77)
4. Gorilla glue
5. Paint brush (I used 1”)
6. Putty knife (I used a 3” taping knife)
7. 2” Extruded Polystyrene
8. Poster board or equivalent (I used the discarded backs from tablets and legal pads)
9. Large paper (I used the reversed side of discarded engineering plans)
10. Newspaper
11. Joint compound
12. Sandpaper
13. Sanding sponge
14. Spray primer
15. Spray paint (I used Rust Oleum Hammered, Copper)
Note: Selection of adhesive is critical when working with plastics such as XPS, since styrene is soluble in several petroleum distillates, such as acetone. XPS does not appear to be damaged by 3M 77, but is dissolved by 3M 90 and petroleum-based contact cement. Additionally, petroleum-based spray paint can soften XPS and polyester resin attacks it quite aggressively.
Eh Lie Us! says: Mar 11, 2013. 3:25 PM
Bravo! Great work.
caitlinsdad says: Mar 6, 2013. 8:11 AM
Nice! That solid wood yoke must weigh a ton. Did you replicate the crack on the bell?
JML Enterprises (author) in reply to caitlinsdadMar 6, 2013. 1:21 PM
The yolk is somewhat heavy. I reduced the weight a bit by building in some voids where I could. I opted to skip the crack. I'd like to build a better one the replicates all of the text.
caitlinsdad in reply to JML EnterprisesMar 6, 2013. 1:42 PM
Maybe next time mount a big ship's bell inside so it would actually ring for those that want to touch the bell. It would be pretty neat to get the patina on the bell and additional details.
sunshiine says: Mar 6, 2013. 12:28 PM
Oh how this would be beautiful adorning my space! Thanks you so much for sharing your hard work and do have a splendorous day!
sunshiine
rimar2000 says: Mar 4, 2013. 7:20 PM
WAW! (What a Work!) Congratulations.
JML Enterprises (author) in reply to rimar2000Mar 5, 2013. 8:36 PM
Thank you very much!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
