Remove these ads by
Signing UpStep 1: Gather the Tools & Parts
White 5mm LEDs (you determine how many to use)
¼ resistors (value determined by how many LEDs you use)
Proto Board
Tools:
Diagonal Cutters
Solder & Soldering Iron
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
I stumbled on this little instructable and thought you may be interested (for the front of your car) in a stripboard layout for a knight rider LED scanner HERE
A voltage regulator can solve this by dropping it to a steady, lower voltage and then use a resistor for each LED (maybe a couple of capacitors to smooth out any other voltage variation).
Other than that, great replacement that will last a while! Been wanting to replace all the lights in mines with LEDs, just have to find powerful ones for the headlights haha
