Life of an Old Timber
91
6
Posted
Introduction: Life of an Old Timber
We had an old timbers and logs which were stored on the air. They lied down outside the house for several years.
When we decided to do the interior design in marine style - we wanted these logs. We did stairs from timber and beams of the stairs from the logs. Unfortunately I don't have photoes of these logs and timbers from the very beginning of our project, but firstly we cleaned them with carpenter's plane (we have electric one). After that we sealed up all the slits with special plastic wood filler. Then we took a grinding machine and sand the wood step-by-step with sanding paper by 80-100-250-500-2000 grit.
After achieving the necessary smothness of the wood we used wood preservative, after drying we coated wood by woodstain (two coats), and finally - three coats of furniture varnish. Between the layers of woodstain we sanded again with sand paper of high grit (2000 or even more if you have). It provides the super smothness of the varnish.
  • Gluten Free Challenge
  • Paper Contest 2018
    Paper Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
6 Comments
How did you attach the ends of the rope to the wood?
Oh, I forgot to say - before glueing the rope into the wood you should roll up the ends of the rope with kind of adhesive tape or electrical tape - in order the rope not to disheveled.
The rope goes through the middle beam and at the ends we glued it into the wood with transparant glue putty and after it had dried up - I cut the excesses.
Thank you. :)
