3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Light Bar Ambient Lighting
  • last photo ←
A light bar can brighten your house through the use of ambient lighting. You can lighten up hallways, add a fading glow effect behind your entertainment center, create new patterns in light graffiti or simply add a light source to your house. There are endless possibilities for lighting with a light bar, it's all up to you!
The parts are fairly cheap and the project is fairly easy. You will need to strip wires, solder leds, and be able to use a power drill. With LEDs cheap and long-lasting this project will add a warm glow to your house.
Once you have purchased the parts you need (You likely have most of them already) actually putting the bar together should take about 3 hours (if you are inexperienced).
This instructable is designed to teach with pictures as well as words. Most of the pictures have notes added to them with tips and information.
*** I am not liable for any injury, property damage, or any other losses that happen within this project. You will be working with electricity and should be careful. Though the voltage and amperages I used in this project are not harmful (or even be felt), using a more powerful electricity source, and the use of hot objects (Soldering Iron & Hot Glue Gun) can cause damage. ***
Step 1Parts & Tools
Parts & Tools
The pieces needed for a LED bar are reasonably cheap. Don't be alarmed at the amount of parts needed - nothing is expensive, all of them are pretty common and easy to use. You probably already have 3/4ths of this stuff right now.
Most of these parts were purchased at The Home Depot and Lowes.
Metal Wire Cover (Light Bar) $5.00 for (1) 5' bar. Used to keep people from tripping over wires in the home or office, I modified it to become my light bar. You could also use wood, PVC pipe, or another material. (Though I suggest something compact and tidy).
Rubber Insulated Clamps (3) $1.25 for 2 - These are used to mount the light bar to a surface.
Electrical Tape (1) $4.00 for 66' - Used to hold pieces together and insulate wires from bar.
Wet Rag - Any cloth or sponge will do, just soak it in water, its used to clean leftover solder off your soldering iron.
LEDs (18 for one light bar) $10 for 100- Pick whatever colors you want. I also suggest fading LEDS. You can use any voltage you want, though most colors fall in two categories, 1.9-2.1v(red, orange,yellow), and 3.0-3.4v (green,blue,white). Brightness is up to you, 10000mcd-18000mcd (Millicandelas) are plenty for night lighting, something like 25,000mcd may be too bright for night time, but good for accent lighting (glowing under furnitur, though 35,000mcd or higher can even be daytime lighting. Real life stores are far too expensive, so on EBay you can get them from Hong Kong for 1/20th the price. I suggest the sellers HKJE LED or LED-HK
Hot Glue Gun $5 - Get a lot of glue sticks, as they will hold things in place and insulate.
Power Supply (1) $1- Any source of power will do, though LEDs run on DC. Your voltage can be whatever you want, but you must choose your own resistors. (Supply Voltage should be higher than the LEDs Forward Voltage, around 300mA for one light bar (Milliamps are the max amount of LEDs you can have). I got three supplies for $3 at my local GoodWill charity.
Resistors (At Least 10) $3 for 100 on EBay, I suggest ResistorsPlus- These keep the LED from taking in too much electricity. It can change a 9 volt or 12 volt power supply into a 3.3 volt for an LED. For my 9 volt supply, I needed 150 Ohm resistors (9 Volts for 2 LEDs in Series). Calculate yours @ ledcalc.com A common rating is wattage, this simply means heat dissipation, you can always have the W number higher than recommended, but never lower. A higher wattage rating costs a tiny bit more, and is larger, for the most part 1/2 watt is fine, unless you begin using ultra-high power LEDs (like Luxeon Stars which can need 3-10W resistors).
20 Gauge Speaker Wire (Around 8-10 feet) - Used to connect the LEDs to the power supply.
Soldering Iron $10 (1) - Cheap, everyone should have one around. A 15 Watt iron from Radioshack works fine.
Solder (1) $3 at Radioshack- Solder with flux. I recommend silver solder at 0.022" thickness and a rosin core, it's easier to flow and more durable. Used to connect LEDs to the Speaker Wire.
Needle-nose Pliers - Used to bend LED legs.
Insulated Quick Disconnects (Optional) $2 for 12- This is used to easily plug the power supply into the light bar. You could just solder the power supply wires straight to the speaker wire, but then you always have the cord attached. (***Update, I now recommend using 2.5mm DC barrel plug connectors, they are much more durable, easier to plug in, and make a stronger connection. Buying them online is semi-random, try eBay as always**
Power Drill (1) - If you don't have one, ask a friend.
13/64" Drill Bit (2) - $1.50 for one. Used to drill the holes in the light bar. 13/64th" is the perfect size for a 5mm LED, it keeps them from going through the hole and holds them in place.
Wire Clippers - Used to cut the legs of LEDs. You can use some small scissors as well.
Awl - Something sharp with a fine point. I'm sure you can find something.
Scissors - Used to cut speaker wire and electrical tape.
Wire Stripper or Knife - Used to strip plastic insulation from the speaker wire.
If you are new to LEDs or soldering, I suggest viewing this guide @ llamma.com
213 comments
1-40 of 213next »
Mar 31, 2012. 6:19 AMkking18 says:
Okay so I have a quick question. How would you add a female and male audio jacks to this circuit so I can play music along with making the lights flash? Currently I have 100 LEDs and a 12V wall plug that has 1amp work of power since thats what I need to run the lights. Pleasepleaseplease help me.
Mar 31, 2012. 6:24 AMkking18 says:
Correction 50 LEDs
Dec 4, 2009. 5:59 PMtckinlay says:
hey this is a really cool. i am 14, do you think this project is suitable for me to make and do you think you could even put your idea into a water feature??
Jan 10, 2012. 7:58 AMMarch n Glory says:
I'm 12. And im making this. Everything is ok, just i dont like the soldering :D
Mar 27, 2011. 12:34 PMbtoast says:
This is a cool instructable, thank you for posting it.
I have a similar question about water. I was thinking about making this to put outside behind a small glass block wall so at night the LEDs will light up the wall, but I'm afraid it will not last long once it rains. Any advice? I was thinking maybe using hot glue around the LEDs and any openings to try and make it water tight.
Also, I'm very new to electrical work, with a 9V power supply and the LEDs only needing 3ish would I be able to double the size of this and make a 10 foot bar?
Thanks.
Mar 27, 2011. 10:57 PMbtoast says:
Thanks for the quick and detailed response. Yes, the block wall is outside, and I see your diagram of having it on top of the blocks, but the blocks I am using are rounded at the top and rounded on the corners; additionally, they are held together using mortar. If I were to place the LEDs on the top, only the top row would be lit as the light would not penetrate the mortar to light the blocks below.
So, what I was thinking was placing it behind the wall and allowing it to shine up along the back of the wall, similar to what you did with the lights behind the couch. With the blocks being clear and diffused it should light the blocks up as a fade from the bottom to the top, the bottom blocks being the brightest. The issue with this is that the lights sine directly up, and thus could not be covered. Maybe if I fill the track with silicone after all the wiring is done to ensure no water can touch the wires that might elevate much risk. I don't know. I am thinking of making one just for the hell of it and seeing how long it lasts.
Thanks again for the response
Jul 19, 2011. 8:57 PMsparx01 says:
*of
How would you go about making a rippling effect?
You know, random dimming if selected LEDs? Thx.
Jan 3, 2011. 8:15 AMjoshleathers says:
would i be able to use your light bar for the light sorce for this instructable.
http://www.instructables.com/id/Music-LED-Light-Box/.
and would any modifications be nessasary?
May 25, 2011. 1:25 AMb1b2b3 says:
Is it really necessary for a transistor on each of the strings of LED's? Is it possible to just do something like this (see attached pic). I assume it would be ok, providing the total power rating of the LED's doesn't exceed the power rating of the transistor.. But I could be missing something?
Denno
May 25, 2011. 1:29 AMb1b2b3 says:
Sorry, doesn't look like the pic uploaded correctly the first time. here it is now, hopefully this one works..
Apr 20, 2011. 4:36 AMmayur.phadte says:
did u mean dat 2500 mAH is capacity of each battery?
if so then totally it will be 5000 mah but just as the capacity is lessened,it shud still remain 2500 mAH,right?
Apr 17, 2011. 8:10 AMmayur.phadte says:
But I was taught in kindergarten that Series=voltage divider in ratio of resistances
Parallel =current divider in ratio of resistances
wat about that?
I am not pointing out anything wrong but trying to learn something.
not arguing but trying to turn this into an informative debate.
Sorry If I hurt you in any way
:P
Apr 13, 2011. 10:21 AMmayur.phadte says:
I dnt really agree with 18*20=360ma thing
With 12 V DC u connect 4 LEDs in series,right?
so they share the same 20mA
So technically every 4 LEDs share 20mA.
SO u could run about 18*4=76 LEDs on that thing.
Correct me if I am wrong
Dec 23, 2010. 8:14 AMbrigs164 says:
i was wondering if a 12v 1amp dc plug would work if im hooking up 5 bars together
Dec 18, 2010. 10:11 AMvj03 says:
Great idea and tutorial!
Oct 27, 2010. 4:47 PMElectroinnovation says:
You should add ebay.com as a source for most of those items. I know leds can cost about $4 for 100 with free shipping.
Oct 28, 2010. 2:53 PMElectroinnovation says:
oh sorry i didn't see that there. I just read the first part that said $10 for 100.
Sep 3, 2010. 10:42 AMpaperairplanecreator says:
i love doing light graffiti!
Aug 24, 2010. 11:37 AMibtassam says:
I'm intending on using around 10 LED's in series for making an LED music box. It has a TIP 31 transistor and is plugged into audio jack. But I have a power supply of 12V, 600mA. Do you think its enough to run all these LED's??
Aug 25, 2010. 11:56 AMibtassam says:
Hey, I knew what it meant by connecting in 'parallel' but I just understood how to do it by seeing this link http://www.theledlight.com/ledcircuits.html . Please correct me if I'm wrong in the next statement. I can connect as many LED's as I want using 'parallel' method(say 15) and adjust my adaptor to 3V and it would work? Do I still need to add resistors to be safe or is it safe enough. Regards, Ibtassam
Aug 25, 2010. 2:27 PMibtassam says:
Woah! Those were SOME led's! Just saw a video of this Luxeon thingie, It's brightness is beyond it's tiny little size. But a bit too fancy for me atm. Thanks for letting me know about the resistance in advance. Because otherwise I was thinking of finding out the actual voltages of my power supply and LED(Clear blue one) by using a multimeter(which I don't own, so would've asked the shopkeeper to measure it for me) and then using ledcalc.com to find the resistance. And, yes, 15 LED's is just about the number I was thinking about, since in parallel I can now connect a hell lot of LED's(more brightness, yayy!!). So I guess, I just go ahead and buy me one 39 ohm 3W resistor?(or any number near it) [Btw, what supply voltage did you assume for the 15 Blue Led's?] And my last question is, related figure posted below, Do I imitate this figure fully( same figure from the parallel section of ledcalc.com) or do I have to make any other change? I had a hard time searching for plexiglass today but found a neat ready-made hollow plexiglass structure for the lights. If the whole thing works out, It'll be the coolest thing I've made. So excited : ] Thanks for assistance! Regards, Ibtassam.
Aug 26, 2010. 12:47 AMibtassam says:
Can you please tell me what voltage I should set my adaptor to, while running parallel circuit of 15 Led's w/ a 39ohm resistor? Should it be set at 3(as its parallel so same voltage '3' would go via all of them) or should it be 4.5(as the forward voltage of led is 3.2 so it better to be above this value?) or should it be set at 12(like you did while using ledcalc.com). I punched in supply 12, led 3.2V and 20mA to get 33ohm which is what you did, I think. Please explain. Regards, Ibtassam
Aug 26, 2010. 7:59 AMibtassam says:
I've another quick important question apart from the one I posted before this one. Can I just put 15 Led's in parallel and adjust my adaptor to 3V(by using built in switch on it)..? It works when I test ran it using 3 LEd's in parallel with supply of 3V. If I do this, do I still have to put in resistance?(since the difference in voltages is very tiny) OR do I have to adjust the adaptor to 12 V and put in the 39ohm resistor for it to work. Regards, Ibtassam
Aug 26, 2010. 10:16 AMibtassam says:
Not sure eh? lol I guess there's only one way to find out. I'll just take the risk and connect all 15 LED's at 3V in parallel and see how many hours, days or months it lasts( and let you know too). As far as I'm concerned, I have a good feeling about this circuit as It kept working for like an hour, when I connected 3 of them at 3V in parallel. If anything goes wrong, I can always spend 50 cents to get 15 more LED's(everything being really cheap here) and connect them the way you mentioned before(at 12V with a 33ohm, 3W resistor). By the way, Just to increase my knowledge I want to ask: Are you saying that there's a chance that voltage may decrease but current may remain at the same high value? But my question is how can the ac-dc adaptor(keeping in mind that I have the adjustable voltage adaptor) change the voltage from 12 to 3 without changing the current. If it doesn't change current, then Isn't there a danger of damaging other stuff that we try to run on 3V without using any resistance? Thanks. Regards, Ibtassam
1-40 of 213next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
161
Author:QuackMasterDan
I have a passion for tweaking things. Whether it be modding video game consoles, creating custom laser displays, or any creations with lights I love solving problems through unorthodox means. I like ...
more »
