3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Light Bar Ambient Lighting
Step 6Snip, Sheath, & Solder
  • last photo ←
LEDs like the ones we are using in this project have two legs. A positive long leg (and a skinny head), and a negative short leg (with a bulky head). The resistor attaches to the front positive leg (see picture) and the resistor is soldered to the positive speaker wire. The purpose of the resistor is to keep the LED from getting overloaded (they will without one, and become very hot and burn out permanently).
Use the pictures as a guide.
Soldering LEDs Together
Bend the legs of each LED to 90 degree angles. Clip the front positive leg so it is short , this is where the resistor will be attached. These are wired in a Series, meaning the LEDs legs meet back to back (postive-negative-positive). See the diagram for a visual illustration.
Set the LEDs into the drilled holes, as this keeps them aligned and pointing in the same direction. Make the legs meet, and touch the soldering iron at the meeting point. Touch your solder to the legs, and it should melt onto the legs binding them together. Now bend the front positive leg into a U shape, repeat for the resistor. This hooks them together and makes it easier to manage. Solder them together.
Soldering LEDs to Wires
After the resistor has been attached to the front positive LED, remove sheathing from the positive speaker wire, and solder the leftover resistor leg to it. Then remove sheathing from the negative speaker wire, and solder the negative LED leg to it. You can now test if your LEDs light up by plugging in your power supply.
Securing/Insulating with Hot Glue
Place the LEDs and the newly attached wires into the bar, and the LEDs go into the holes. Make sure that no LED legs or exposed wire is touching the bar. The LEDs and wire will naturally want to move around, so press the LEDs down with pliers so they are flush with the holes, pour on a lot of hot glue, and wait for it to dry.
Repeat this step 8 more times, and then its time to finish everything up.
6 comments
Aug 11, 2010. 1:31 AMMillenium_Bt says:
And how do you keep the LEDs from conducting with the metall bar? Greets
Jul 21, 2010. 10:26 PMOnay91 says:
I don't want to sound like an electronics noob, but I have a question. Do the positive and negative wires just run along the sides of the wire covering, and then just stop at one end? I know one end is needed to be soldered to the power supply, but what do you do with the other end? I'm not planning on putting in the quick disconnects. Also, what switch (I would use that to turn it on/off instead of unplugging it) would you recommend using? Thanks
Jul 27, 2010. 2:13 PMOnay91 says:
Thanks, I'm starting to understand this more. I have another question, though. If the voltage difference between the two wires is the same as the supply voltage (for you, its 9V), then why do you need such high ohm resistors? Aren't you essentially hooking up 18 LEDs in parallel? Or is the voltage supply regulated such that there isn't a voltage drop that you'd get from a battery? I hope that my question isn't too confusing
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
161
Author:QuackMasterDan
I have a passion for tweaking things. Whether it be modding video game consoles, creating custom laser displays, or any creations with lights I love solving problems through unorthodox means. I like ...
more »
