THIS POST IS NOT MEANT TO PRESENT A "BETTER" WAY, IT SIMPLY PRESENTS A DIFFERENT WAY.
This instructable covers the entire process, from a new light bulb to a new lamp. It includes the hollowing out of the bulb. However, you'll need to come up with your own base for the lamp.
Special thanks to nm918273 for the original instructions on how to hollow a light bulb.
Bigger thanks to my little bro Tanner for shooting the pics.
I did my best to include a lot of photos and detailed steps.
Hope you enjoy it.
~Tom
Remove these ads by
Signing UpStep 1Materials Needed!
-Light Bulb
-Salt
-Pop Can
-Old Sock
-Lamp Oil
Tools:
-Needle Nose Pliers
-Flathead Screw Driver
-Exacto Knife
-Big Ol' Nail
-Scissors
the glass blub is completely closed, the electronics are cast inside the glass, its an way to make te lamp more effecient and safe. im only looking for a good solution to refil it !
if German light bulbs are like English ones, then they're much more stubborn than the American ones seem to be, but it's still possible to do this. Use something soft to protect the bulb, grip it firmly by the metal part, and tap th black glass repeatedly, very hard, using controlled force and a small scredriver or other instrument. Eventually the glass will start to crack, and by combining the various tricks mentioned above you should be able to clear out all the black glass. It took me about 20 minutes per bulb, with a 50% success rate (the bits you're trying to break are much stronger than the part you want to keep whole...)
I recommend wearing glasses or goggles and working somewhere easy to sweep!
Have fun,
Jethro
I just finished mine, its an awesome idea. It actually made me join here. I used two magnets, a small one inside the bulb and one hidden under a tealight shell. Now it stands stable and i can lean it over to a side without worries.
eve
basically tippmannphreak is saying it looks like an improvised incendiary device, like a molotov cocktail http://en.wikipedia.org/wiki/Molotov_cocktail
Meths (that purple stuff) smells like neat alcohol, has a much dimmer flame (not great for lighting unless you make a mantle or something) but is much cleaner burning. It is *very* flammable, meths spills are dangerous so i wouldn't recommend it for an unstable lamp design like this one.
Lamp oil (if that's what you mean by oil) smells better, burns a little cleaner than paraffin and has a nice bright flame but is more expensive. I don't know how flammable it is if spilled.
I wouldn't try burning other types of oil, veggie oil has some water content so spits/crackles a lot, smokes and doesn't smell very good, and I haven't tried engine oil or other types but I'd steer away from it. Paraffin or lamp oil are probably your best bet.
