3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Light Bulb Lamp
Step 2Disassembling/Cleaning the Light Bulb
First, take your drill/punch and tap at the bottom of the light bulb, until you break the black glass.
Then tap on the inner tube inside the bulb with the wire in it, then extract the insides of the beast.
Now, go grab your granular substance (sand works best) and put some into the bulb, now add water and swirl the mixture, while your swirling you'll notice that the inner white coating will flake off.
Once all the white coating has detached itself from the inside of the bulb, rinse the bulb thoroughly and set it aside.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
76
Author:bumpus
I am a jack of all trades and a master of none. =The world is prone to blind acceptance.= Opinions/Truths: Politeness shouldn't be faked, having no rules is a rule, just because you're an adult d...
more »
