3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Light Bulb Lamp
Step 3The Cap
The Cap
After you have cleaned the innards of the bulb and washed the inside, grab your bottle cap and shoe lace. Locate the center of the cap and drill your hole, start with a small hole and work your way up to just under shoe-lace-diameter. Before you cut your shoe lace, tape the middle with a little bit of tape, so when you do cut (in the middle of the tap band), you wont have a frayed mess. Thread your taped end into the fresh wound in your bottle cap and pull the lace through. Screw the cap (with the lace threaded) onto the top of light bulb and do a measure test, you want a little slack at the bottom, but not much. Take off the cap and find where your magnets have run off too.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
76
Author:bumpus
I am a jack of all trades and a master of none. =The world is prone to blind acceptance.= Opinions/Truths: Politeness shouldn't be faked, having no rules is a rule, just because you're an adult d...
more »
