3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Light Bulbs Candle Holders
Want to re use those shot light bulbs rather than throw them away. Why not make them into a Halloween decoration.
You will need:
an old light bulb
a candle stick
a screwdriver
coarse sandpaper
A saw
WARNING: This Instructable involves breaking glass and sharp metal, therefore I would advise protective gloves and goggles to be worn during the first couple of steps. Make sure you have a responsible adult with you if you are under 18.
Step 1The Light Bulb
The Light Bulb
CAUTION: Use Protective GLOVES and GOGGLES
To remove the bottom metal area of the light bulb is very tricky. Cut the top of the metal off ( approx. 3 rings down) as this should be just before the empty space stops. When that has been removed you will need to carefully cut the rest of the metal away by prising it away from the metal on the inside. The metal can be very sharp so be careful, please
3 comments
Oct 21, 2011. 2:17 AMysmith3 says:
Looks nice.Thank you. You may also be interesting to visit :http://www.keengardeners.co.uk
Oct 19, 2011. 10:00 AMkillbox says:
Getting wet/dry sandpaper and sanding it inside a dishtub is a good way to go, less liekly to shatter, gets you a better edge, and is less likely to make airborne glass dust, which is not good for you!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:Jally9(Twitter)
Hello there, so...this is me and I do me thing :-) I am a creative person I would like to believe. I paint pictures for around my house. I write books and scripts (not ones to be published just for l...
more »
