Light Controlled Servo Using LinkitONE
Published
Introduction: Light Controlled Servo Using LinkitONE
Hello,
Here i'll show you how you can control your servo motor using light!
More light, more the speed of servo motor
Step 1: Parts
You will need-
1 x LDR
1 x LinkitONE
1 x Mini Servo
Step 2: Attach Servo Motor
Now we will build the servo motor. After that we will attach it.
We will using PIN 9 to attach the servo.
Step 3: Connect Light Sensor
Connect your LDR. Connect it into A0 pin and ground pin one.
Step 4: Connect USB
Now connect your USB cable with laptop and board so we can power the board.
Step 5: Write Code
Burn this code to your board.
#include'servo.h'
Servo myservo;
int val;
void setup() { myservo.attach(9);
void loop() {
val = analogRead(A0);
val = map(val, 0, 1023, 0, 179);
myservo.write(val);
delay(15);
Step 6: Test the Servo
Now test your servo!
more light, more speed!
    • Planter Challenge
      Planter Challenge
    • Clocks Contest
      Clocks Contest
    • Casting Contest
      Casting Contest
    2 Comments
    My SG90 doesn't work correctly with LinkIt ONE. Why?
    Nice...
    What volt is your servo. My tower pro SG90 servo not run correctly in mediatek board.
