Light Detector Solar Panel With Arduino
Introduction: Light Detector Solar Panel With Arduino
This is a project for those who use solar panels and want to increase the efficiency of them.
This project is a scaled down version of what can be achieved with bigger solar panels.
Step 1: Items You Will Need
Step 2: Attach the Motor to the Stand
Step 3: Place the Sensors on the Corners of the Stand
Step 4: Wiring Up the Arduino
I used 10k ohm resistors.
Arduino code for this project :
Bellow you can find a tutorial on how to control a stepper motor with an Arduino :
Step 5: Starting It Up
When you start it up the arduino will think that it is on the position 0, for this reason always position the solar panel accordingly.
Step 6: Final Thoughts
This idea can increase the efficiency of a solar panel so it is a good idea for those who live in a house
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
    Hello! Where did you buy each element to make the project? Thanks
    Hi! The aluminium sheet and the plastic piece are from a hardware store. The solar panel and the Arduino with the light sensors are from
    Great project my friend and first time I see a light detector using a servo motor, an upgrade would be for the panel not just to turn to the four corners but in the midpoints also or where is the most light falling.
    Why a stepper motor over a standard servo motor? What is the advantage? (Just curious to hear why you choose one part over another.)
    I used a stepper motor because i wanted it to be able to turn 360° and the only servo i had home could only achieve 180°. Other than that i don't prefer steppers over servos especially because the servos are easier to use. For the stepper I had to calculate how many impulses are needed for a full turn.
    Nah the powers don't let me put it up -how silly
    Hello, where can I buy a small panel similar to that? Thanks.
    I think you can find them on Ebay, Aliexpress and I am prietty shure in many more places, they are quite cheap
