3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Light-Duty Custom Spools for ABS Plastic
Having just joined the Milwaukee Makerspace , I found a lot of interesting side-projects that needed tackling. It just so happens that I haven't done any wood-working since 10th grade, so many of these projects are experiments designed to reaffirm what I thought I knew and teach me a damned good lesson about what I never knew in the first place.
For this project, a couple of makers had some concerns about the ABS plastic filament for the Makerbot (3D printer; Cupcake version) being lightly coiled, zip-tied together, and strewn about the desk. In one instance, the filament kinked and a print got interrupted midway through.
After a brief discussion, I decided that this was worth tackling and I designed two projects: making spools for the filament and a spool holder to keep them above the desk and out of the way.
(Note: I'm including what I used here, but this is by no means the only way to do it. I used what I was familiar with and what we had on-hand. Your results may very. Consult physician before stopping project. Do not attempt on an empty stomach. Do not drive or operate other heavy machinery while attempting to drill, cut, screw, sand, or stain project. Have a nice day. Be kind, rewind. )
For this Instructable, you will need:
-A sheet of light, 1/4 inch plywood (I believe that a 2'x3' piece should work fine)
-Some narrow, heavy-duty cardboard tubing (this one came from a roll of plastic sheeting), 2 1/4" outer diameter, 1/4" thick
-JB Kwik (quick setting 2 part epoxy) AND a softer, two part epoxy. (I found that the JB Weld tacked things in place nicely, but I wanted something easier to mold so I could work it into the joints)
-A saw (I used a bandsaw here, but I suppose you could get the same result with a hand-held scroll saw)
-A disc sander (for smoothing out the plywood discs)
-A power drill (I used a drill press)
-A hole saw (Make generic, unfunny whole/hole homonym joke here)
-A compass (The exciting, circle-drawing kind, not the boring, magnetic kind)
-A beer (...As a reward for after you've finished the project. I do not condone drinking and operating power tools; this is how people end up in the ER with fence posts stapled to their face....)
Step 1The Dimensions
The Dimensions
Fortunately, I had a factory made spool on hand that I could measure to get the approximate size.
Remember that the center has to be hollow so that it can slide onto a dowel for use. I ran into a problem here, but more on that later.
First, get the outer dimensions of the circles for the outside of your spool. Mine came to about 8" in diameter.
Next, measure the inner diameter of your cardboard tube. Mine was 2".
A friendly tip : I find it easiest when cutting circles to place them as close to the edge of the material as I can. Not only does this cut down on waste, but it reduces cutting time by up to 1/64 of a minute or, for the metric-inclined, 1/64 of a minute.
Using your compass, set it to the outer diameter and trace 8 circles on your 1/4" plywood.
I cannot stress this enough: Always mark your center-point!
It is incredibly easy to lose that tiny dot left by the point of your compass that marks the exact center of each piece. You might not know it, but you will need it at some point (and, in fact, at several points in this Instructable). Put a nice little "X" there. Even better, you might want to consider hitting it with some fluorescent paint.
Set your compass to the interior diameter of your cardboard tube and trace another circle using that wonderfully highlighted, blacklighted, X-marks-the-spot-center-point that you so thoughtfully marked after the previous step.
Wow. You should now have donuts traced on a board. Take a step back and congratulate yourself while no one's looking.
6 comments
Oct 30, 2011. 12:52 AMjoen says:
Nice instructable. There are as many ways to make reels as there are readers of this site. I needed some reels and made mine from tin cans. I used a can opener that undoes the crimp on the lid rather than cutting it for the sides. Safer that way. Used a smaller can body for the inner part of the reel and stitched them together with paper clip wire. Hot glued the pointy ends of the paper clips and they are better than the store bought ones I have. I still like the way you made what you needed out of what you had on hand.
Well done, reels and instructable..
Oct 31, 2011. 2:09 AMjoen says:
I mean that quite literally. I made two holes on the lid on the inner and outer side of the body of the can and then made one hole right next to them on the inner can body then ran wire to tie them together. If you try to do that with yours I would suggest threading all the wires through the holes loosely first then tightening them down.
The pictures are a little fuzzy. (I used a 2.5X loupe on an eyeball web cam) Hopefully they are clear enough to see what I mean.
Hope this helps.
Oct 28, 2011. 3:49 PMzazenergy says:
Great Instructable!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:MercuryCrest
