Light Inducing Seizure Warning System
226
Posted in TechnologyAssistive-technology
Introduction: Light Inducing Seizure Warning System
About: Aerospace Engineer working in Software Development with a passion for Hardware.
In 1997, a Pokemon episode was banned since the flashing lights in the episode caused seizures in many Japanese Children. Inspired by this event, this is a photosensor mount on someone's glasses to detected the light sources in front of a subject that could be seizure inducing and send a warning signal to a user by buzzer.
Step 1: BoM
* Arduino
* Photosensor
* Buzzer
Tools:
* Hot glue gun and hot glue
* Soldering Iron and solder
Step 2: Soldering
Solder a voltage divider onto the photoresistor as shown above.
* Solder a 10kΩ resistor onto one of the terminals.
* On this same terminal, solder a wire.
* Solder another wire onto the other pin of the photresistor
Step 3: Wiring
Follow the table below for the connections between of the photosensor and the buzzer to the Arduino
I/OI/O pinArduino Pin
Photosensor1A0
Photosensor2GND**
Buzzer*19
Buzzer*2GND**
* Order of pins do not matter for the buzzer
** The Arduino board has at least 3 GND pins
Step 4: Code and Upload
Upload the following code to the Arduino.
//cosntants for the pins where sensors are plugged into.
const int sensorPin = 0; const int buzzPin = 9;
unsigned long minute1;
float time1;
//Set up some global variables for the light level an initial value.
int dark;  // initial value
int lightVal;   // light reading
void setup()
  // We'll set up the LED pin to be an output.
  dark = 300;
  //we will take a single reading from the light sensor and store it in the lightCal        //variable. This will give us a prelinary value to compare against in the loop
void loop()
  lightVal = analogRead(sensorPin); // read the current light levels
  //if lightVal is less than our initial reading withing a threshold then it is dark.
    while (lightVal > dark) {  // still sitting
    tone (buzzPin, 1000, 100);
    delay (100);
    noTone(buzzPin);  }
Step 5: Mount
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Microcontroller Contest
    2 Comments
    would this work for fluorescent lights, cause they can trigger my seizures also?
    I'd have to look into the FFT for these sensors. I'll get back to you in a few days. If not, PM me to remind me.
