3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Light Pen and Glow Book
Bedtime is tricky for our little ones.  They like to look at books, but I don't want to leave the light on.  If they have a flashlight, they'll leave that on all night and use up the batteries.
I've seen books that glow in the dark, but it's a pain to hold them open to every page and let the glow powder charge in the light before letting them have the book in the dark.
I wanted a book that had glowing elements, along with a light that only lights up when you press the tip against the page.  I didn't find any, so I made them myself.  I used a book we already had, Goodnight Moon, because Benjamin and Lilith already love it (and we have more than one copy).
I didn't feel like buying anything, so I used things we already had.  For the pen, I used:
large syringe (you can use some other tube that fits the batteries)
2 AA batteries
1 white LED from an old string of holiday lights (I would've used a UV led but I accidentally burned the last two out yesterday; it would've worked so much better than plain white, because it'd make the glow powder go crazy)
hookup wire
hot glue
solder (along with a soldering iron)
a small spring (something non conductive like plastic would work better than metal here; I had to coat mine in hot glue)
red felt (because the syringe was much larger than the batteries)
For the glow book, I used:
board book
epoxy
strontium aluminate glow powder
(this is the good stuff; other cheaper glow powder doesn't work as well.  you'll want something really reactive like this so that the book glows nicely after just a little bit of time under the glow pen)
toothpick
parchment paper, or something else you can mix the epoxy on and then throw away
piece of a straw cut at an angle to scoop up the glow powder
Step 1Make the LED circuit
  • last photo ←
I used a spring because I wanted the LED to only turn on when the tip was pressed.
LEDs have a positive and negative wire.  The longer one is usually positive (unless someone snipped it).  I soldered a wire to the positive end of the LED.  First I burned off the plastic coating at the end of a red hookup wire, pulling off the black char and exposing the wire.  Then I twisted that wire into the positive wire of the LED.
I heated up the butane soldering iron, then touched it to the twisted wires to heat them up.  The solder I used already has a rosin core, so I didn't worry about using flux.  Flux is something that helps solder stick and flow where it's supposed to.  When the wires were hot (it takes a couple seconds), I touched the end of the solder to the twisted wires.  It melted and flowed into the gaps, solidifying and strengthening the connection between the two wires.
That, in a nutshell, is soldering.  It's gluing something using conductive metal glue.
After the wire was attached, I wanted to insulate it to make sure it wouldn't short.  I used hot glue from a glue gun to cover the exposed metal on that side.
I then soldered a short, stronger piece of metal (actually a folded bit of wire) to the negative side of the LED.  I also glued a spring to the LED, making sure to cover both ends of the wire with hot glue because I didn't want the spring to conduct anything.  The piece of metal was shorter than the spring at rest; it's longer than the spring when the spring is compressed.  This is so you can press the LED, compress the spring, and allow the metal to touch the battery.  That will complete the circuit and allow the LED to turn on.
Once I was satisfied with the position of the spring and the metal connecting to the negative side of the LED, I got the batteries to test out the circuit.  I lined two AA batteries up with the negative side toward the LED and the positive side away.  The end of the wire connecting to the positive side of the LED was touching the positive end of one battery.  I was able to press the LED and spring closer to the batteries, completing the circuit and lighting the LED.
6 comments
Mar 12, 2012. 3:52 AMstringstretcher says:
fantastic idea!
Jan 3, 2012. 8:56 PMbajablue says:
You completely amaze me!
Jan 3, 2012. 9:52 AMjonnyd55 says:
I like the instructable and I like your work so please dont take this as a criticism because its not. I would be careful letting young children associating syringes with toys, If they saw one in a park they would be more likely to pick it up. Jonny
Jan 3, 2012. 12:14 AMgerbilboy says:
Suggestion for the pen body - 1/2" PVC Schedule 40 pipe is just the right size to hold AA batteries.
Jan 2, 2012. 11:45 PMMrballeng says:
You are my hero.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
270
Author:supersoftdrink(my etsy store)
I took over my husband's Instructables login last year to make a couple instructables for two contests. He was only using it to browse stuff, anyway. I have a different and sillier name elsewhere on...
more »
