Introduction: Light Sensing Bristlebot
Picture of Light Sensing Bristlebot
This "level up" from your basic brainless bristlebot has the capacity to seek out or "run away" from light sources. Its great fun to lead through a maze with a lighter or torch - like a moth to the flame. Install the light sensors the other way around and it takes on cockroach characteristics, moving away from the light.
This design also employs a capacitor to power the motor, allowing for endless recharges.
A great "next step up" project for fine tuning your soldering techniques. In my experinece total beginners (11 year olds with no previous soldering experience) can manage these but need a little support and guidance here and there.
See it in action
Step 1: Tools and Materials
Picture of Tools and Materials
Tools:
  • Soldering iron with a reasonably fine point
  • Small wire cutters
  • Large wire cutters
  • Solder
Materials:
  • 1 Cylindrical supercapacitor. Capacitance 1F - 5F voltage 2.7V - 3.6V. 2
  • (see extras for notes on capacitors)
  • Darlington phototransistors (light sensors)
  • 2 Cellphone buzzer motors, 3V.
  • A toothbrush (an old one is fine)
  • A pair of batteries to charge your capacitor
Bits:
  • Small length of narrow heat shrink tubing.
  • A small offcut of wire to connect the terminals of the batteries
  • A piece of tape
This exercise has 3 parts – The bot unit, the brush, and the charger.
Step 2: Building the Bot Unit: Capacitor
Picture of Building the Bot Unit: Capacitor
  1. Identify the negative and positive leads of your capacitor – there is usually a stripe along the negative side, and the positive lead will be longer. These will look like antennae when your buzzbot is assembled, but they are actually used for charging the capacitor, to power the motors.
  2. Trim the longer lead so that both are the same length. This is mainly cosmetic, but does make charging a little easier.
  3. Thread the piece of heat shrink (really only 2 mm!) onto the positive lead of the capacitor and shrink it in place. It doesn’t matter if it’s still a bit loose, it will be fixed in place as we go ahead.
Step 3: Building the Bot Unit: Light Sensors
Picture of Building the Bot Unit: Light Sensors
  1. Take a look at your light sensors- these are directional so you need to identify the positive and negative leads as well as the front and back. Hint - The side with the bump on it is the front (needs to be facing forward in your finished bot). The negative lead is the one with the big ‘block’ within the sensor.
  1. Bend the negative terminal of one light sensor at about 1cm (the further down the longer your “eyestalks will be) – see picture Trim the negative lead on the other light sensor at about the same position as the bend in the first.
  2. You now need to solder the two negatives together as shown. 1. Prep the leads with solder (tin them with enough solder to make your join). 2. Hold the pieces in place and solder together (helping hands or strategic blu-tak will help here).
  3. Line up your sensors on the capacitor as shown – the negative lead of the sensor on the right needs to meet the negative lead of the capacitor (we will attach these in a later step), while these are insulated from the positive lead of the capacitor by the heatshrink.
  4. You can bend the positive leads of the sensors back at 90 degrees so they will lie along the side of the capacitor.
Step 4: Building the Bot Unit: Motors
Picture of Building the Bot Unit: Motors
  1. Tin (add a little solder to) the ends of both leads on both motors.
  2. Add a dot of solder to the positive lead on the capacitor – just above the heatshrink.
  3. Now attach both red motor leads to that dot of solder on the positive capacitor lead – twisting the wire ends together first will make this easier.
Step 5: Building the Bot Unit: Motors Cont...
Picture of Building the Bot Unit: Motors Cont...
  1. Add a dot of solder to each of the positive terminals of the light sensors just after the bend.
    Attach the blue lead of one motor to each.
  2. Line up your light sensors on the capacitor again – the negative lead of the sensors should contact the negative lead on the capacitor.
Step 6: Building the Bot Unit: Assembly
Picture of Building the Bot Unit: Assembly
  1. Organise your components so that each motor is on the opposite side of the capacitor to its sensor (blue lead attached to sensor on opposite side), this ensures your bot will follow a light instead of running away from it.
  2. Fix in place ready to solder (use helping hands or blu tak down the side of the capacitor).
  3. Solder the sensor/capacitor connection.
  4. At this stage you might want to trim the positive capacitor leads or leave them as is – this is purely cosmetic and up to you.
  5. Splay “antennae” slightly in order to reach / fit charging station – see charging station instructions.
  6. When you come to assemble your bot ensure the motors and corresponding light sensors are on opposite sides in order to ensure correct turning patterns (turning towards light sources). Attach motors firmly (to the capacitor or side of the brush) to ensure maximum vibration transmission to bristles.
Step 7: Modifying a Brush
Picture of Modifying a Brush
You can use any small brush for this, but we think toothbrushes work best for a bot of this scale.
Consider:
  1. Wider brushes will be more stable.
  2. Bigger (heavier) brushes will be slower.
  3. Used toothbrush bristles are nicely splayed so tend to be stable.
The key thing is to have angled bristles. To do this we modify our toothbrushes using hot and cold water.
  1. Dunk the brush into a cup of boiling (recently boiled) water for about 30’s (this is not a precise measure, just enough to soften the plastic.
  2. Run the cold tap in the sink through the next step.
  3. Smoosh the brush on the bottom of the sink – sliding the brush forward will ensure the bristles angle backwards – try to keep it level so the bristles are evenly smooshed.
  4. The bristles should be quite smooshed at this point – don’t worry, they will bounce back.
  5. Trim the handle off the toothbrush.
  6. Wait for the bristles to dry completely (they don’t work very well when they’re wet).
  7. Attach you bot, charge and go!
Step 8: Detour: Bot Assembly Tips
Picture of Detour: Bot Assembly Tips
In assembling your bot ensure the motors and corresponding light sensors are on opposite sides in order to ensure correct turning patterns (turning towards light sources).
Attach motors to the toothbrush firmly to ensure maximum vibration transmission to bristles.
Try different positioning of the unit and motors to see what works best (we use blu-tak for attachment to allow modification).
Step 9: Building Your Charging Station
Picture of Building Your Charging Station
  1. You need 3V to charge these capacitors.
  2. We used 2 AA’s (bigger batteries will get you more charges).
  3. Connect one set of terminals (+ve to –ve) using whatever conductor you have about (wire offcuts are ideal). You can solder or stick.
Soldering – you really need to heat the battery terminal in order to ensure the solder will stick (or it will just break away).
Sticking – simply taping a wire across the terminals at one end (+ve to -ve) will do the job, but tends to shake loose so you need to check/ hold it firmly in place when charging.
  1. Tape the batteries together.
  2. Charge – complete the circuit using the capacitor, touching the negative to negative and positive to positive – the capacitor will charge fully in a few seconds.
Step 10: Technical Thinkings
Capacitors
  1. 1F capacitors work great, but larger ones will run the bot for longer.
  2. Capacitors larger than 5F are physically too large at the present time to fit comfortably on a toothbrush head.
  3. DON’T use a capacitor with a higher voltage rating than 3.6V - high voltage capacitors can cause sparking and burns. We find that 2.7V, 3F capacitors are the best.
Buzzy motors
  1. We use 10mm disc or button-type cellphone buzzer motors.
  2. Make sure to use buzzer motors, not the linear actuator buzzers used in high-end smartphones, which look the same but are more expensive and need a computer chip to drive them.
  3. There are other kinds of cellphone buzzer motors that will work, but we find that the 10mm disc motors work best.
Toothbrushes
  1. Wider toothbrushes work better.
  2. Most toothbrushes are too narrow, so your bot will fall over easily.
  3. Manky old used toothbrushes with the bristles splayed and curled often work well, and can give your buzzbot a unique personality!
Known design flaw
  1. The connection between the capacitor and light sensors is a weak point and does tend to rattle free eventually (with all that buzzing) - but is an easy mend. We do have a better solution for this - coming soon.
Dweedledee (author)2017-01-26
Can I confirm that when you guys say F you mean μF? Also, can I confirm the voltage issue? Looking through a bunch of caps at my local Maker hangout The lowest I could find was 6.5 with most of them being 25V and 50V as well as other high denominations. Is there something similar going on here?
Bristlebotics (author)Dweedledee2017-01-26
No, we mean F (Farads) not uF (microfarads).
These are not your grandma's capacitors. They are supercapacitors a.k.a. ultracapacitors. See below for advice about how/where to buy them.
Dweedledee (author)Bristlebotics2017-01-28
Ok thanks, that helps!
Dweedledee (author)Dweedledee2017-02-11
I ended up with 4.7F capacitors at 2.5 volts. After reading a little on playing with capacitors it says to never charge at a higher voltage than the caps are rated for, will two AA (3V) not be too much or is the half-volt negligible? I would like to do this with younger people and I don't want anyone exploding a cap.
Bristlebotics (author)Dweedledee2017-02-14
3V won't cause these caps to explode. Having said that, they do in fact store enough energy to do some damage (about 20J, the energy of 1Kg dropped from 2m) if you could transfer it to kinetic energy of a projectile. That's called a rail gun, a fun-with-capacitors project for bigger kids on another day. Otherwise most of the energy in an exploding capacitor is dissipated harmlessly. In practice if a capacitor got hot and especially if it started to swell I would dispose of it, but I have not seen that happen with these caps/bots. There's a video at https://www.youtube.com/watch?v=4yZxNKyd_lM showing an 'exploding' 2.5V 4.7F capacitor.
There is some danger of burning if the leads of a charged capacitor are shorted. They have essentially no internal resistance, so all the charge comes out at once. I know from personal experience that you can get a small burn on your fingers if you push the leads together. I have no personal experience of what happens if you lick the leads, but am not keen to find out (unless you want to try it and let me know ;-) ).
With younger kids (up to about 10 yo) we make simpler bots with 1F caps. There's an attachment in one of the other comments that describes how to make these. They're a lot of fun especially when you get a table-top full of them buzzing around - it's hard even for an adult not to think that they are little animals with minds of their own ...
PraneethC6 (author)2017-01-28
If we can use LDR instead of a phototransistor, please tell me how to do it
enstain (author)2017-01-24
Hey, nice thingy here, but could you please be more specific on the parts? I tried to find the "Darlington phototransistors" on ebay, but the results are not what I need here. Could you tell me the model of the ones you used, so I can at least use it as a reference? Thank you.
Bristlebotics (author)enstain2017-01-24
Hi Enstain:
The sensors we use are OP560 "side looker" Darlington phototransistors, which can be bought online e.g. from Mouser. A photodiode + transistor might be a slightly cheaper option, but this would be more complicated. I don't like complicated.
enstain (author)Bristlebotics2017-01-25
Thanks :) I feel the same way about "complicated"
Parts ordered. With luck I will get them before the end of March and try building this thingy :D
Dweedledee (author)enstain2017-01-28
Have had some trouble finding these nice flat ones, find a lot of round ones though. Am grateful for any part-numbers people find.
Can someone tell me how to use LDRs instead of photo transistors..?
Please answer me quickly.. :)
MrsMWhitaker (author)2017-01-27
THANK YOU!!!!
MrsMWhitaker (author)2017-01-24
I love this idea! I have been using bristle-bots in my robotics summer camps for several years and this up-grade is perfect. However, I have not been able to find the capacitors...any chance of getting suggested vendors?
CalebDundas (author)MrsMWhitaker2017-01-27
search for super capacitor on amazon they should have a lot of choices.
MrsMWhitaker (author)CalebDundas2017-01-27
I have done extensive searching and have not been able to find a supplier for a capacitor that small...the smallest I have found is 4v
Bristlebotics made it! (author)MrsMWhitaker2017-01-25
Hi Mrs Whitaker: We use bristlebots for outreach programmes, encouraging kids to be scientists and engineers. I've uploaded a pdf (below) that describes simpler supercap-based bristlebots that are relatively easy for children to make (younger ones need close supervision with a soldering iron ... but you knew that).
You can buy supercaps online from sites like Mouser, RS Components, Element14 and others. It may depend on where you live, but these days you can get stuff delivered just about anywhere in a day or two.
The search tools on electronic component supplier sites are pretty daunting if you don't have a pretty good idea what you want. Element14 lists 56,621 different kinds of capacitors!
Use the search terms:
supercapacitor 2.7V 1F
or
supercapacitor 2.7V 3F
This should narrow it down to a handful of choices.
The 1F supercaps are perfect for the simple 1-motor bots described in the pdf. They'll run the bot for about a minute before needing a recharge - a pretty good match to the attention span of a 6 year old.
The light-following bots draw more power and are better with 3F or 4F caps.
There are other, similar capacitors that will work if you are keen enough to figure out the online search tools. Don't pick anything bigger than 3.6V and 5F. The energy stored in a capacitor goes up with the square of the voltage and they start getting dangerous!
Fedek6 (author)2017-01-25
Maybe a video how it works? :)
Bristlebotics (author)Fedek62017-01-25
https://www.youtube.com/watch?v=CMfASw4i3zw
robotobor (author)2017-01-24
I think this is very cool and cute! Have you considered using small solar panels? I built as small photovore kit that is tiny like this, but uses pager motors for legs. I am definitely going to add your bot to my buggy not collection. Thanks for sharing!
Bristlebotics (author)robotobor2017-01-24
Hi Robotobor:
Good idea. We did put a Solarbotics kit on a Bristlebot - it's kinda cool, hangs round doing nothing, then has a spurt of activity, then stops, then ...
Hadn't thought of combining the two, but it's a great idea - a solar-powered steerable bristlebot could seek sunlight, and keep itself awake!
nqtronix (author)2017-01-24
It's nifty idea to charge the capacitor through its own pins and disguise the as antennae. It blends in nicely with the overall look, I like that!
M.C. Langer (author)2017-01-24
Awesome!
Donald Bell (author)2017-01-22
I love this design! Bristlebots are fun, but there's always the built-in disappointment of the coin cell inevitably dying and being impossible to extract. The charging idea solves this and the light-sensing gives it more of a purpose. Great work.
ChristyI (author)2017-01-20
Hey Bristlebotics I like your use of directional light sensors.
One thing you might want to include is a warning about what happens if you get the polarity mixed up when charging your supercap, it's so easy to do. I like to use some red and black shrink tube or just a red and black sharpie - anything to remind someone (including me) to check polarity. You did use black heat shrink but you put it on the + side
Bristlebotics (author)ChristyI2017-01-20
good idea, we will think on an edit. We (and our testing team) haven't actually blown anything up yet but we wouldn't want to inflict that on anyone else :)
neuralian (author)ChristyI2017-01-20
Good point. Thanks.
neuralian (author)2017-01-19
neuralian (author)neuralian2017-01-20
Looks like you can't access Amadeo's page if you are not a friend of Amadeo, and apparently some people aren't! So I put a copy on youtube:
https://youtu.be/CMfASw4i3zw
random_builder (author)2017-01-20
This is a GREAT invention.
Swansong (author)2017-01-19
Neat! This looks fun :)
About This Instructable
33,295views
296favorites
License:
More by Bristlebotics:Light sensing bristlebot
Add instructable to:
