Light Spectrum Clock
 by turiphro
Featured
Step 4: Wooden frame
Saw the wood in the appropriate pieces. You need a top and bottom, two sides and a small front and back to hide the electronics underneath the LED cubes (see images). For the front and back ones, you can simply take a piece of the same size as the top and bottom pieces and sawing lengthwise. Make sure that the side pieces have the appropriate height (twice the wood thickness + the width of the front/back pieces + the height of the cubes).
Assemble the frame except for the second side. Drill a hole on the spot you want the power cable to enter the clock (I made one at the back, right behind the spot where the Arduino would be, such that it is possible to connect and disconnect the USB cable from the outside even after closing the frame). Push four nails into the bottom of the foamboard frame on a distance from the front and back, equal to the thickness of the wood (see image). Now shove the foamboard frame, including the electronics underneath, in the wooden frame, make sure the electronics will not be able to move, and finish the frame.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
