Light Synced Speaker
5,142
54
Posted
Introduction: Light Synced Speaker
In this project I make a light synced color changing LED.
Normal LEDs don't work.
They only work with transistors and stuff but I'm trying to make this as simple as possible :)
Step 1: Parts
To make the color changing light synced speaker you need-
1 speaker
1 color changing led
2 wires that are stripped
1 headphone jack
Step 2: Attach One Wire
Attach one wire of the Led to one wire on the speaker. It dose t matter which wires because we will use AC current.
Step 3: Attach Two Wires
Attach 2 wires to the two remaining wires on the speaker and the Led.
Step 4: Wrap
Wrap the two ends of the wires on these parts of the headphone jack. They need to be touching them.
Step 5: Secure It
Secure the connections with tape.
Step 6: Test
Test the circuit by plugging it in. You need to put the radio or whatever you are going to Use on its highest volume because the LED takes a lot of electricity from the speaker.
Step 7: After Testing
After testing it and seeing if it works you can tape everything to the back. Make sure wires don't touch others.
The bass might be too loud but it still works ._.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
3 Comments
kudos to figuring this out.
It doesn't work until the voltage is higher than the LED threshold (3.2V for a white LED), I know you're using a synced colored LED but it has a threshold as well. There's no limit of the current and moreover, the LED is feed with reverse voltage half the time, which makes it last far less than expected.
Simple, yes. But this probably will drain the battery of your audio player and loose a lot of sound quality.
Building a small single transistor amplifier for your LED with an external battery pack as you said would really be more reliable. You could even add three frequency filters to separate the low, mid and highs into three LEDs. You could even use a few LM3915 IC and build a real audio visualizer but that gets complicated an it's pretty much impossible to build without a breadboard and some basic skills at soldering. :)
