3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Light Tablet
Light Tablet
Any serious or not serious artist needs a lightbox. Lightboxes are used to illuminate a picture from behind so that you can trace the image on to an overlaying sheet of paper. In a pinch, you can also use this to look at x-ray film to see how your bones are healing after that Knex or bicycling mishap.
Many others have constructed lightboxes or light tables before. My design was inspired by the new Mac aluminum keyboards. They are sleek, look pretty cool, and does it job in a minimalist package. This is my entry into the Let It Glow contest. A frugal investment for a professional tool costing several times more.
Step 1Get the Essentials...
This time we will dig into the wood scrap, although it is possible to make this out of laminated cardboard or formed metal. You will need :
  • 1" x 2" wood stock
  • 1" x 4" or 1" x 6" wood stock (1" x 3" was used in this prototype project)
  • 3/4" #8 wood screws
  • white paint
  • wood glue
  • jig saw (hand saw works also)
  • sandpaper (orbital sander or other power sander)
  • drill, screwdriver
  • ...if you are lucky enough to have - pocket hole jig/drill or plate joiner or dowel jig
And purchase these at Big Orange if you don't have anywhere to scavenge:
  • 23 inch undercabinet slimline plug-in flourescent light - $19 USD
This long light is pretty compact and has a built-in on/off switch and has a diffuser cover for the bulb. It does output a fairly white light even though it has a "warm white" bulb.
  • 18" x 24" Lexan clear polycarbonate plastic sheet -$14 USD
The difference between the "good" grade acrylic and the "best" Lexan plastic was only a few dollars. The Lexan is a bit more scratch resistant and stiffer which is better since it will be our drawing surface. I opted to use this instead of glass since this is a portable unit that can be put to the side when not in use. Try to keep the protective cover on the plastic as long as you can to avoid scratching it inadvertently.
45 comments
1-40 of 45next »
Jul 22, 2009. 6:00 PMbvulgarin says:
Congratulations! It's a nice work!
Jul 28, 2008. 5:56 PMKeith-Kid says:
NOW, I need one of these. So, I'm actually making one. Thanks caitlinsdad!
Jul 1, 2008. 8:10 AMwebster32 says:
2 simple improvements that will increase the light output of the panel significantly -- 1. Place the light in the middle of the table -- your light tube allows light out both sides and the top. 2. Use aluminum foil and some cardboard or another bright reflector on both sides of the light tube. The best way to do this is to make a panel that will run (along the length of the tube) from the top edge of the table, right under the glass, down to the long side of the tube. Then make another panel for the opposite half. This will reflect the light evenly up to the table surface. Provided your diffusion layer is even enough, there shouldn't be any "distracting" glaring lines from the bulb. If the diffusion from paint and sanding isn't enough, consider applying a sheet of thin paper to the bottom side of the table top.
Jun 22, 2008. 8:32 PMKeith-Kid says:
LOL at the second picture!!!
May 25, 2008. 10:19 AMThornburg says:
These things are so awesome. We used them in my graphic art class (it also had this projector so we could explain are drawing) and they are so easy to trace.
Jun 19, 2008. 12:33 AMcreative zen says:
hey im in a graphics arts class too at my high school. Its nice to see people with the same attributes as you once in a while.
Jun 19, 2008. 7:33 AMThornburg says:
It was a great class, and thanks.
May 25, 2008. 10:53 AMThornburg says:
Although, you could add another light to the other side. Looks kinda dark.
May 25, 2008. 11:22 AMThornburg says:
Must have been. Anyway looks like a store bought one (which are expensive).
May 25, 2008. 11:42 AMThornburg says:
Your welcome. This is also random but I don't have a Mac, but an Ipod. Macs are only worth the price half of the time.
Jun 12, 2008. 3:50 AMXellers says:
Wouldn't it be easier to modify a scanner to do this? Just remove everything but the gears, pulleys, light, and inverter and hook that up directly to a power supply. Then, all you would have to do is move the light to the desired position.
Jun 13, 2008. 7:36 PMXellers says:
1) I have a recycling center near me and I've found several scanners there. 2) That's true, but many instructables here require a bit of soldering. I guess people will be able to. 3) That's true. But it might still work for smaller works. 4)Although this is true, building something useful from trash would feel much more rewarding than from bought materials. I've actually done a scanner rewiring, and found that it does work. But since the costs of this project are so low, you're right, building it would be a great idea. I'll try it!
Jun 14, 2008. 11:16 AMXellers says:
I just posed a slideshow on the matter here is a direct link:
http://www.instructables.com/id/Free-Cold-Cathode-Lighting/
May 31, 2008. 4:01 PMthermoelectric says:
You could use EL panels instead of the light altogether Flexible, very energy efficent light box
May 19, 2008. 10:28 PMGorillazMiko says:
I WANT GORILLAZMIKO GLUE.
May 31, 2008. 4:05 PMthermoelectric says:
Yes Send them to 123 fake street,Fake suburb, Fake land
May 19, 2008. 11:44 PMPatrik says:
Cool - this is definitely one of the lighter designs I've seen. A diffuser from a broken LCD screen would even out the lighting a bit more...
May 22, 2008. 12:56 PMhelifino says:
light diffuser panels are cheap and readily available at your local home improvement warehouse. Just make sure the "pointy side" faces the light source.
May 22, 2008. 10:00 PMhelifino says:
A large part of the discoloration problem is that they trap dust and never get cleaned. In this case, the dust-trap portion would be pointed down, and should mostly alleviate the problem.
May 22, 2008. 6:12 PMmartymunch says:
This is a great idea, if only I'd known this fifteen years ago. I will probably make one of these for my kids. Thanks!
May 23, 2008. 5:10 AMmartymunch says:
Thank you! Yeah I have done that already. I also liked the giant magnet and your other robo 'ibles. You are an inspiration, and ya make me laugh.
May 19, 2008. 10:26 PMGorillazMiko says:
NOOO STOP WATERING ME KEITH-KID!!!! :P
Keith-Kid's real name is Bryant.
Anyways, nice job, I will vote for you, along with a +5/5 stars.
Thank you for not making too much fun of me this time. ;-)
May 20, 2008. 4:26 PMbumpus says:
its just Yant, drop the "Br" :D
May 20, 2008. 4:38 PMGorillazMiko says:
Why?
May 21, 2008. 1:33 PMbumpus says:
its a chat room thing
May 20, 2008. 6:08 AMKeith-Kid says:
(removed by author or community request)
ooohhh......I saw it.
May 20, 2008. 6:11 AMKeith-Kid says:
Not so Famous?!!!!!!!!!
1-40 of 45next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
247
Author:caitlinsdad
This author has not updated their profile. They might or might not get around to it sometime.
