Light Triggered Motor
 by seraine
I haven't seen a light switch for a motor that draws around an amp, so I thought that I would make one. The product works well - if I shine a laser on it, I can trigger it from across a room quite easily.
Also, I am thirteen years old. (Mandatory mention of age for robot's challenge)
Step 1: Materials
You will need:
Materials:
A motor. I took one out of a broken Nerf Barricade.
A TIP31 transistor. $0.20 http://www.taydaelectronics.com/tip31c-tip31-npn-transistor-3a-100v.html
A 2N3906 transistor or similar PNP transistor. $0.02 http://www.taydaelectronics.com/2n3906-general-propose-pnp-transistor.html
A battery holder. I used one that held 3 AA's. $0.14 http://www.taydaelectronics.com/aa-battery-holder-5.html
A SFH 314 phototransistor. $0.58 http://www.mouser.com/ProductDetail/OSRAM-Opto-Semiconductors/SFH-314/?qs=K5ta8V%252bWhtbR6gV8hNfmATd6ftDkb0eH0AduyQe8MSk%3d
Perf Board. I used one I had laying around, but you should use Radioshack's miniboard, which costs around $2.19. http://www.radioshack.com/product/index.jsp?productId=2104052
A laser pointer is recommended to activate the light switch.
The total cost came to around $5, with shipping.
Tools:
Soldering Iron
Screw driver
Wire strippers
Optional: Breadboard
Must be able to solder and read schematics
dsandds2003 says: Jul 15, 2012. 7:42 PM
Can you use higher voltages to drive a larger motor?
seraine (author) in reply to dsandds2003Jul 16, 2012. 7:34 PM
By this, do you mean using this with motors that are more than 4.5 volts? If so, I believe that the motor you use can be up to 40 volts. I base this on the fact that the maximum collector emitter voltage on the TIP31 datasheet is 40.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
