Light Up Rock Wall Stairwell, With Solar Lights
 by michaelalanjones
Featured
Solar garden lights are designed to be shoved into the dirt along a sidewalk path, like spikes. I wanted to illuminate the stairwell of my rock wall, at my Civil War-era farmhouse. This shows how I did it, with cheap, but bright Westinghouse solar lights - $4/each, at Wal-Mart.
Step 1: Remove the rod on the bottom
This is one of those $4 Westinghouse solar lights. You don't need the stake on the bottom, just the top part, which contains the solar cell, battery, light and lens. I had to doctor the picture below - basically remove the stake and save it for something else.
michaelalanjones (author) says: Jun 3, 2009. 5:59 AM
This is what the lights look like at night - note that it is very difficult to take a picture at night, even though you can see, because our eyes are better than cameras. The lights are quite bright, and without the stakes on them, they look like "custom" wall lights.
bobby sissom in reply to michaelalanjonesNov 24, 2010. 2:05 PM
thank you for the night shot ,i have a circular stone wall i made ,i have to back around every morning,now i will be able to make it much more visable at four a.m.
stringfellow says: Jul 4, 2010. 7:45 AM
You inspired me, I am in the process of building a rock wall and last week I came across your instructable, here are some photo's with my twist
stringfellow in reply to stringfellowJul 4, 2010. 8:41 AM
Thanks for the Inspiration!!!
sideways says: Jul 6, 2009. 3:16 PM
Fantastic idea. Thanks for taking the time to make & post an instructable. You've given me some ideas for using those lights around my home in areas where a stake wasn't practicle.
Ralex says: Jul 6, 2009. 4:19 AM
Instead of making an oval shape ring, what you could do is make a circle that is a little smaller then the lens(tube) so that the tube is pushing outwards in the circle...you have the same result
js43.com says: Jun 6, 2009. 4:16 AM
I'm having a hard time finding the lights at Walmart. Any chance you could provide a part number? Great Idea BTW !!!!
quiviran in reply to js43.comJun 7, 2009. 1:29 PM
There are crates (literally) of them in the lawn and garden section.
August Spies says: Jun 4, 2009. 11:59 AM
I love solar garden lights - a solar panel, a bunch of LEDs, a light sensor , AA battery and a charging circuit...what else could you want in a dirt-cheap consumer electronic? If you're gonna be re-wiring them, why not put the panels on top of the stones making up the staircase walls? You could run the wires down through one of the cracks then along the wires holding it in, so it wouldn't be much more visible, and you'd have the benefit of a much wider arc of sunlight, which could more than double your power without any more panels.
michaelalanjones (author) in reply to August SpiesJun 4, 2009. 12:23 PM
In considering a re-wire, I was merely offering a suggestion to 'ventifact', to resolve the shady area charging dilemma they described in their location. I would not re-wire the solar lights in this instructable; that would not be necessary or prudent. There is enough ambient light to charge the lights as is; to move the solar cells to the top of the wall would actually put them in harm's way. Tree limbs could fall on them. Sometimes people put things on the top of the wall, like watering cans, tools (while working nearby), etc. Sometimes people sit on the wall. Having the lights below the top surface of the wall protects the light on one side; that lowers the risk of falling debris hitting it by 25%.
ventifact says: Jun 4, 2009. 7:04 AM
I have a similar set-up in a very shady area. Every few days I move the lamps to a sunny place to recharge and replace them in the evening.
michaelalanjones (author) in reply to ventifactJun 4, 2009. 7:44 AM
I also have some other solar lights (the old plastic kind), with replaceable AA NiCad cells. You know, if you are good at soldering wires, you could extend the wire a little, and move the solar cell to a place where it could reach the sunlight, but leave the electronics and LED bulb+lens in the original location. Of course, the longer the wire is, the more current it would take away from recharging the cells. And you should try to use the same wire thickness. Think "extension cord" here. Polarity is important; keep the red wire going to the red wire, black wire going to the black wire. If you do this, you could/should wrap the solar cell panel in clear strapping tape to protect it from the elements, i.e., "laminating" it. Currently, most of these solar cells has a thin film (or the like) over the top/bottom to protect the wire part of teh solar cell.
lukethedog says: Jun 4, 2009. 7:16 AM
Nice idea. To get a better photo at night switch your camera to A (apature priority) then you can adjust the shuter speed to 25 or 40 not 400, 800 or 1000 as the camera does in auto. You will need to hold still but, you will capture more light (the shutter stays open longer) Just hold still and you will get what you are looking for. But, as a side note this is not a photo instructable it was meant to show you how to use inexpensive solar lights to light a walkway without disturbing the 100 year old stone work. Was I the only one to get that :) Nice instructable, thanks for taking the time to put it together.
Holden_vy_s says: Jun 3, 2009. 1:23 AM
Should've gotten some night pictures so we can see them in action. Do they light the stairs up very well?
crapflinger says: Jun 2, 2009. 10:33 AM
i've been thinking of getting some of those light's for my deck but couldn't evaluate the brightness....how bright are they? could you take a night time pic to show how bright they are maybe? perhaps? please?
fkuk in reply to crapflingerJun 3, 2009. 1:05 AM
it depends on the ones you buy some are brighter than others go to the shops and buy just one and test it out
elnino2783 says: Jun 2, 2009. 2:40 PM
A night shot would be cool to see. Also, I wonder if some redundancy could be added to this setup. Like buying 4 of these lights instead of 2. Basically you would put one set on top of the other and they would both charge during the daytime. At night the top ones would would be lit and the bottom ones won't turn on until the top ones become too dim essentially doubling the time a set of light are on. You could even put the solar panel for the top one underneath the bottom so that the light from the bottom one recharges the top one a bit more and it can turn on a bit more when the bottom one fades out.
Kiteman says: Jun 2, 2009. 4:32 AM
Simple and effective - I like it.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
