Light Up Rooms With Solar Power - DIY 10$ Project
23,136
263
21
Posted in TechnologyLeds
Introduction: Light Up Rooms With Solar Power - DIY 10$ Project
About: My name is Simon Sörensen and I am the creator of RCLifeOn. I´m 19 years old and live in a town called Trollhättan, located in the southwestern part of Sweden. I´ve been in the RC hobby...
Solar power is amazing! You can power motors, lights or any electrical device, and they are available all over the world for a very reasonable prices.
In this Instructable I will show you have to use solar panels to power LED lights. The estimated cost for this project is only 10$!
Solar Contest 2016
Third Prize in the
Solar Contest 2016
Step 1: Materials
    You think solar panels are expensive? Think again! One 6V 150mA can be bought from Ebay for only 1,5$! You will need 4 of them so that's a total of 6$ worth of solar panels. However, if you want to have really bright LED lights I recommend more than 4 solar panels.
    Solar panel: http://www.ebay.com/itm/301966354364?_trksid=p205...
    The LED lights can also be bought from Ebay very inexpensively. Price will depend on numerous factors like length, type, color and if you require the lights to be waterproof. From this seller I was able to purchas 2m of white 3528 LED lights for only 2$
    LED lights:http://www.ebay.com/itm/SMD-3528-5050-5630-5M-RGB...
    You will also need a cable long enough to reach from the solar panels to the LED lights. This is also extremely cheap at just a couple of dollars (10m; 20AWG; black).
    Wire:http://www.ebay.com/itm/1-2-5-10M-Silicone-Wire-Ca...
    Note: This is not the materials used in the video. I had everything at home so I only got some solar panels.
    Step 2: Solar Panel Connection
    The reason why we need 4 solar panels is to achieve the correct voltage and current. 1 solar panel has a voltage of 6 volts, and a current of 150mA. In order to power the LED lights we need a minimum of 12 volts and 200mA (depends on the length of LED strip). That's why we have to separate the solar panels into two different groups.
    Basically, take two of your 4 solar panels, let's call them solar panel 1 and 2. Solder the positive pad from solar panel 1 to the negative pad on solar panel 2. Then solder wires to the remaining positive and negative pads on each solar panel. This is what's called conecting circuits in series. What we have done from these two solar panels (1 and 2) is increased the voltage from 6V to 12V. This means, instead of having two solar panels producing 6V and 150mA each, we now have two solar panels working together to produce 12V 150mA. Do the same with solar panels 3 and 4.
    By connecting the two serperate groups of solar panels in parallel we can make 1 big solar panel producing 12V and 300mA. This will be more than enough to power several meters of LED lights.
    Step 3: Holder Platform
    You really don't need to get too fancy here. Take a scrap piece of foam, plastic or anything of that nature (nothing conductive though). I used a square piece of foam larger than what I needed to easily add more solar panels in the future.
    All solar panels are waterproof and these cheap panels are very rigid so no protection is necessary. Use plenty of glue to secure them to the piece of foam!
    Step 4: Cable/Wire Connection
    From your solar panels to the LED lights you will have a rather long cable/wires going in-between. Since I didn't have that long wires in my home, I went with a long cable. I solder the positive wire to the inner pin, and the negative wire to the outer shell of my cable.
    Note that the longer your wire, the more power loss you will have. Don't worry too much about the length, but in case you have several meters of unused wire just pushed behind your furniture, you might just aswell cut it off.
    Step 5: Panel Placement and Cable Management
    Obviously you want to place your solar panel where it will be exposed to the sun, so make sure you choose wisely. Use double-sided tape to attach the holder firmly to any surface, and begin bringing your cable inside to the LED lights.
    To secure the cable agains the roof I used a tape resistant to water, but that was a little overkill. You can easily use duct tape.
    Step 6: Connecting the LED Lights
    Take the other end of your cable/wires from the solar panels and solder an electronic switch to the circuit in order to turn it on and off. This is optional but recommended, if you don't have a switch you could simply solder a connector and unplug when you want to turn it off.
    I also used a PDB (power distrubution board) to easier connect more LED lights in the future. However, this step is also optional. If you don't want to use a PDB, you could simply connect the cable/wire from the solar panels to the LED lights and you will have working light wherever you want.
    Step 7: Attach the Switch and LED's
    Since the LED's are pre-glue you can basically attach it to any surface, which is great because it makes the installation very easy. You can also cut the LED's at certain locations, so if you want to use shorter lenghts of LED's you can do that!
    Step 8: Turn It On!
    Get creative! Remember that you can purchase the LED's in multiple colors, and don't worry about the power, even on rainy days the LED's will have enough power to stay lit. Also, the more solar panels you connect the brighter the LED's will be.
    Want to see more awesome projects like this? Check out my YouTube-channel here: https://www.youtube.com/user/RcLifeOnSimon
      • Microcontroller Contest
      • Space Challenge
        Space Challenge
      • Science of Cooking
        Science of Cooking
      21 Comments
      Very well thought out and suitable even for a novice. A very practical daily use of solar power. Thanks.
      great work again! you got my vote!
      Wow this is a great instructable, well done and thanks for sharing
      Thanks man! Have a nice day.
      Excellent job! Also, you have a beautiful, neat and well organized work area too!
      I was wondering if you considered a storage battery for nite time viewing?
      Also, don't you have to seal the the panels against the weather?
      No, they are waterproof.
      Sorry for late answer! Yes, I just ordered a charge controller and a battery. Thanks man!
      Very nice. What was the final overall length of your cable on this project? Did you note how much (if any) power loss was experienced because of its length?
      I didn't experience any significant power loss, but according to basic electronics there should be. The length of my cable was probably 20m (65 feet).
      Thanks for reading my Instructable. Have a nice day!
      I'm very sorry to be negative but you need lights when the sun is gone. So, you need to charge a battery with your panels and use the battery to power the leds...
      You don't have to apologise. Yes, you would need battery to power the LED's at night, you would also need a charge controller. All of sudden this ends up being a 100$ project instead of just 10$. Thanks for your comment, have a nice day!
      Very nice job, I might have run the cable thru that corner vent or wall somehow to keep from accidentally crimping the cable, but I like it anyway and will most likely use this idea in my basement where the lights get left on too much. Thanks for the share. Semper Fi
      Glad I could inspire you, good luck!
      *sepArate* What's the point of having a spell-checker if you don't use it?
      Sorry about that. Thanks for pointing it out though.
      Wow! Thanks for all of that information! Think I may have to go back to school for this one :-) Much appreciated.
      Cool, I live in Alaska. I want to try some solar lighting in the winter (yes, when it is incredibly dark and cold), but hey...... So.... I am wondering if there is a way to figure out how much (many) panels you would need based on the LED lights that you are trying to fire up. I got some nice commercial grade ones (for a song at habitat for humanity), but I have no clue how to figure out what they might need to actually make them shine. Any ideas, info would be very appreciated. Thanks!
      You have to figure out how many milliamps 1 meter of LED lights require to stay lit. Google the name of your lights (usually stated on the website), or use a voltmeter: https://www.google.se/search?q=how+to+measure+amps&ie=utf-8&oe=utf-8&client=firefox-b-ab&gfe_rd=cr&ei=FMjcV-aNBtCq8wfRpqPgBQ
      Let's pretend the current required for 1 meter of LED lights is 200mA. If you purchase the 6V 150mA solar panels linked in the description of my video, you will need 4 of them. Almost all LED's needs 12V, and that means we have to connect the solar panels in series.Connecting solar panels in series will double the voltage, but you also need to increase the current. That's why we also connect the solar panels in parallel.
      All of this is covered in the video: https://youtu.be/lvo_uAPiKSU
      thats awesome. how hard would it be to add a battery bank to use at night?
