Light Weight Tripod Camera Slider for DSLR
 by MacGyver9
Featured
This tutorial will show how I made this tripod mounted camera slider for under $50. The design uses hardware available in most hardware/home improvement stores. I wanted a design that I could use with any of my tripods & cameras. This design utilizes the removal head aspect of tripods as shown in the last two photos.
Due to the high prices for camera sliders, I decided to create my own camera slider to use for movie making and stereo photography. All of the DIY projects for camera sliders I found weren’t suitable for use on a tripod and the commercial versions were simply too expensive. The main objective was to make a camera slider that would be light weight, yet sturdy enough to use with a professional DSLR.
How sturdy is this slider? The tripod head shown in the photo weighs 11 oz, my Canon SX20IS camera weighs 27 oz (1.7 lbs) and my Nikon D7000 camera with battery grip weighs 64 oz (4 lbs). Therefore, when using the Canon SX20IS there is 38 oz (2.3 lbs) on the slider and when using the Nikon D7000 there is 75 oz (4.7 lbs) on the slider. The slider itself weighs about 39 oz (2.4 lbs).
Step 1: Tools & Materials
Tools needed:
- Drill
- Hacksaw
- Wrench
- Metal hand file
- Pop rivet tool
Materials list:
Quantity     Part Description
1          24" clamp & cut guide
4          3/8-16 x 1 1/4" chrome button screws
1          3/8” x ¾”  <OR> ¼” x ¾” hex bolt (depending on the size of your tripod mounting screw)
1          3/8” <OR> ¼” bar knob (depending on the size of your tripod mounting screw)
4          3/8-16 nuts
2          1/2" x 4" PVC risers – outdoor use
1          1/2" x 4' aluminum round-tube
1          flat 4-plug electrical box cover
4          3/16” x (1/8” to ¼” grip) rivets & back-up plates (washers)
4          3/4" 1-hole conduit straps
4          1/4" x 1/2" hex bolts with lock nuts
2          2" x 4 1/4" aluminum angle-stock (left over from previous dolly project)
Notes:
a. Not all PVC risers are manufactured to the same tolerances, so be sure that the ones you select for this project slip easily over the ½” aluminum round-tube.
b. Before selecting your 24" clamp & cut guide, be sure to read the first paragraph of step 2.
muresanpaulcristian says: Apr 3, 2013. 7:49 AM
Hallo man, sorry for disturbing you with this kind of problem, but i can't find anywhere that cut guide, could you give me a website where from to buy it. Thanks man.
MacGyver9 (author) in reply to muresanpaulcristianApr 3, 2013. 2:09 PM
Glad you asked. I meant to post with the original Instructable but forgot. The guide I used for the slider was a 24" All-In-One Contractor Straight Edge Clamping Tool Guide from E. Emerson Tool Co.(http://www.eemersontool.com/products/products.html#c ). I got my at my local Menards hardware store. They had the 24", 50" and 99" sizes. I checked the cost at Menards today and the costs were: $28.98 for the 24" (SKU 2443812 - on sale today in the store for $15.99), $37.98 for the 50" (SKU 2443816) and $99.98 for the 99" (SKU 2442818).
pdub77 says: Jan 31, 2013. 6:52 AM
Elegant. I like this a lot. This is hand made, but looks like something you could buy in a shop. Well done! How smooth is this thing? Can you use it for video work with any sort of precision?
MacGyver9 (author) in reply to pdub77Jan 31, 2013. 8:50 AM
Probably the reason it looks like pro gear is because I'm "picky" about how the final results will look. I took my time to make sure everything fit like you would expect if you purchased from a dealer.
Without adding anything to the rails, the contact between the PVC risers and the aluminum round-tube is smooth. However, in practice I use a rag with silicone spray and wipe the aluminum round-tube. This results in a very smooth movement with no messy oils, etc. on the rails. The video I posted previously was before I started using silicone on the rails - the silicone makes the transitions very smooth. I'm not sure how much precision you would need with your video, but it works very nice for my needs.
The length may be too short for some people, however the length allows me to carry the rails in my tripod bag with the tripod, monopod, ballheads and remote shutter release everywhere I take the tripod - especially nice when on vacations.
Zaphod Beetlebrox says: Jun 20, 2012. 4:39 PM
For even cheaper this would work.
MacGyver9 (author) in reply to Zaphod BeetlebroxJun 20, 2012. 5:21 PM
True, less expensive, but too heavy (bulky) for any of my tripods. I needed something more portable that I can use in museums, etc. I don't think the PVC on one you mentioned would be able to support the weight of my Nikon setup either, so that's why I ruled out PVC for my design.
benjaminxuu in reply to MacGyver9Jun 27, 2012. 7:39 PM
I guess the PVC tube is only for the slider which does not bear weight.
MacGyver9 (author) in reply to benjaminxuuJun 28, 2012. 12:23 PM
While @Beetlebrox's design incorporates PVC, my design also incorporates PVC material made for outdoor use (4 inch "risers"). Depending on how & where you use the PVC in the design, PVC can be very light-weight & strong. PVC also tends to have a low coefficient of friction when used on metal surfaces.
Zaphod Beetlebrox in reply to benjaminxuuJun 28, 2012. 10:41 AM
I tried to use pvc because it would be lighter than wood and cheaper.
Zaphod Beetlebrox in reply to MacGyver9Jun 20, 2012. 7:16 PM
K, it worked for me. But I'm using a smaller DSLR and go pros mainly. No battery pack.
leviathan937 says: Jun 24, 2012. 8:58 PM
I wonder if it would be worth adding a small pully on the inside of each end and a counter weight, so the further you move the camera to one side the further the counter would move out to the other side.
Just for a little extra stability, especially if you where using a larger lens or other attachments adding a bit of weight...
MacGyver9 (author) in reply to leviathan937Jun 26, 2012. 7:10 PM
Now that's seems like it would be worth trying. I've got a couple ideas on how to implement the slider, so I think I might just give it a try. I'll post an update if successful.
Edit: After thinking about this over night, I'm not so sure it would be a good idea in my case. One of my objectives was to keep it portable (light weight), so to add a counter-weight would be counter-productive (no pun intended). Currently I hang my camera bag from the bottom of the tripod in order to make the tripod more stable, and the camera slider stays level when the lighter camera (2.3 lbs) is at the end. I have also tested my heavier Nikon setup (almost 5 lbs) about half way to the end of the slider and the tripod & slider have both remained stable.
leviathan937 in reply to MacGyver9Jun 26, 2012. 8:44 PM
True, it is just extra weight, and from your pictures it looks like the slider is not much wider (if at all) than your tripod.
A counter weight would be of more use i think if you had a longer slider, or if you were using it in strong winds etc. where a strong gust could throw it off balance.
If you did include a counter weight I would also be inclined to attach it to the string with a clip so it can be easily removed. (there when you need it, not when you dont.)
MacGyver9 (author) says: Jun 19, 2012. 7:54 PM
Attached is a 3D image I created today - not the best, but it was shot at the same time as the sample video I also created with the rail: http://www.flickr.com/photos/47409821@N08/7405387206/
earlyflyer in reply to MacGyver9Jun 25, 2012. 9:26 AM
Very nice rig and excellent results. Thanks for taking the time to share it!
miriallen says: Jun 25, 2012. 6:46 AM
So you watch Film Riot, too! Neat!
isko1960 says: Jun 24, 2012. 9:30 AM
Excellent tripod.
I made ​​a different way. but it seems
http://masterlom.moy.su/load/foto/foto_video_tekhnika/shtativ_tripod_dlja_foto_video_tekhniki/40-1-0-213
And how do you ensure the correct center of gravity?
csherrit in reply to isko1960Jun 24, 2012. 5:16 PM
Hey good job of placing a dangerous link !
MacGyver9 (author) in reply to isko1960Jun 24, 2012. 11:55 AM
This Instructable is actually regarding the camera slider rather than the tripod. The tripod shown in the Instructable is one of my commercial tripods (Promaster SystemPro carbon fiber T525P). The reason the tripod & head are shown is to demonstrate how the camera slider is used with a removable head tripod.
snotty says: Jun 20, 2012. 5:36 PM
HAAA I spent like $1k making something similar...
mikeasaurus says: Jun 17, 2012. 10:27 PM
Looks good. Do you have photos to show us from your rig?
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
