3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Light activated blinking LEDs
In this Instructable I will show you how to put together a flashing LED circuit that turns on when you wave your hand over it, blinks for a second or two, and then fades out.
I got the schematic for the flashing circuit from steven123654's instructable which can be found at:
http://www.instructables.com/id/LED-flashing-circuit/
I have since modified the circuit to include a light dependant resistor that is used as a momentary switch.
Step 1The Idea
Besides being a fun project, and a great first LED project, if you make 5-10 of these circuits and put them together, it creates a pretty awesome wave effect as you pass your hand over each module.
I found the idea for this circuit on youtube. someone had made a table of LED modules that flashed as they cast shadows on the table. It looked pretty cool but I decided that it would be more fluid looking if there were more individual modules instead of large squares of LEDs all activating at once so I went to work and came up with this circuit.
Here's a list of the recommended parts:
-a breadboard
-100K ohm potentiometer
-a 3904 NPN transistor
-22 micro Farad capacitor
-1000 micro Farad capacitor (minimum, I use two caps and one is a 2200 uf)
-an LED
-a light dependent resistor
-two 1K ohm resistors
-one 100 ohm resistor
-a 555 timer IC
-a bunch of wires to connect it all
I'm pretty sure all of these parts can be bought at RadioShack.
If you already have the stuff check out the schematic on the next page to get started.
23 comments
Oct 14, 2011. 10:14 PMAmar143institute says:
This Instructable can Use many ways.....
Aug 17, 2010. 7:45 PMbrsram says:
Sorry, I am confused. Is it 330 uF or 2200 uF or 22 uF? The image notes says 2200 and 1000 uF, the list of recommended parts says 22 and 1000 (in parenthesis it says (I use 2 caps and one is 2200 uF) while the schematic shows 330 and 1000 uF. Which one is it? Also, what is the voltage used?
Oct 19, 2010. 9:00 AMviper518 says:
Can anyone tell me the parts that I need and how to hook up 10-15 leds in a row and have them light 1 at a time down through the row of leds and to vary the speed. Thanks
Jan 13, 2010. 1:12 AMsapc says:
ry shorting the ldr make sure the pots away from flammable stuff and the smoke and smell sets of smoke alarms buts its awsome
Jan 13, 2010. 1:11 AMsapc says:
try shorting the ldr make sure the pots away from flammable stuff and the smoke and smell sets of smoke alarms buts its awsome
Jan 13, 2010. 1:09 AMsapc says:
Dec 29, 2009. 4:55 AMashikch says:
dude! its working but the thing is LEds are blinking when there is shadow but not after the shadow is removed as given in the schematic ??how to make that blinking after the shadow is removed??
Dec 29, 2009. 4:47 AMashikch says:
dude! i tried this circuit but LEds are not blinking!! :(
but LEds are glowing when there is a shadow on the LDR ..I tried a lot with pot and thn removed a resister with 7th pin but still there is no blinking Im thinking to change 1000uF capacitor to 2000uF ?? pls help me !!
May 28, 2009. 4:02 PMdave92 says:
you never said in the parts list that you need a 330uf capacitor
Mar 23, 2009. 9:17 AMEngrJayze says:
i am using this circuit for my project...i get a flashing LED all the time if i put a power supply to it..the LDR doesn't seem to do anything..can you help me? I need to finish this as soon as possible.. I can't understand how to connect the Potentiometer and LDR..can you provide a high quality image of your actual breadboard so that i can see where did i go wrong..hope to hear from you soon..thank you
Apr 3, 2009. 3:22 AMEngrJayze says:
Thank you for answering my inquiries..I opted to change some values to make my circuit work.. I also figured out that the LDR I used is only 10mm with 15K resistance..I also have some issues with the Pot's connection..but all are fixed now..It's already my summer vacation..thanks for your circuit
Mar 10, 2009. 8:14 AMtchiseen says:
Do you think it would be possible to use instead of a LDR, A PIR Motion sensor, to make sometihng like the Interactive Coffee table?
Feb 28, 2009. 3:28 PMblast2469 says:
I used your schematic and it worked perfect for me, no errors in drawing cause it worked, lol. Would like to see an add for different rates of flash for multiple LEDs in the project. very nicely done, it was easy to follow and a nice layout.
Feb 6, 2009. 12:17 PMbobbyk881 says:
What would happen if the led lash activated the flash again?
Feb 6, 2009. 1:04 PMbobbyk881 says:
I thought it would be cool if if flashed long enough to trigger a second flash. so basicly the first flash would go off then the same LED would flash twice as fast.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:sabre
Student @ University of North Texas working towards a Mechanical and Energy Engineering Major. I do all kinds of fun little projects. I'm currently trying to scavenge old pictures so I can publish a f...
more »
