3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Light bulb snow globes
Step 2Preparing light bulb
  • last photo ←
Warning: taking apart a light bulb can be messy, dangerous, and can even explode, please take care while doing this, use safety glasses and gloves. Light bulb glass breaks quite easily so be careful when dismantling the bulb and when assembling the snow globes.
The following instructable gives great instructions on how to hollow out a light bulb if you find mine confusing: How to hollow out a lightbulb
*Also the idea of using a sock to protect your hands are from: http://www.instructables.com/id/Light-Bulb-Lamp-Another-Option/
Thanks
  • Using pliers, remove the shiny bit (contact point) on the end of the light bulb.
  • With a knife or screwdriver break up the brown/black glass.
  • Cover the bulb with a sock*, hold it in one hand (don't hold from the bottom), with pliers or a screw driver put pressure on the filament inside the bulb to break it up.
  • Remove broken filament bits still attached to the bulb with pliers.
  • Work a knife under the edge of the metal base and it should come off fairly easily.
  • Wash out the inner frosted coating of the light bulb with water, if it doesn't wash out easily try adding some sand or salt and swirl it around.
  • With steel wool or a kitchen scrubby remove the label on top of the bulb.
5 comments
Dec 7, 2009. 6:08 PMDon Cattaree says:
Is it necessary to take off the metal base?
Dec 8, 2009. 1:19 PMDon Cattaree says:
Thanks
Dec 28, 2008. 8:26 AMmontdor1 says:
In from the weakest point -- always a good strategy. Anyway, remember everyone: a light bulb electrical socket (standard, 120 volt) is AC and will only accept AC devices, of course. One may change the AC to DC to do a particular job, like a 120v run LED you can find in any variety store. There are electronics in the devices for proper volt, amp, and resistance conversion.
Dec 18, 2008. 6:25 PMtesseliot says:
Hey! I tried to do that last year and it exploded the second time because I was too impatient. I was using a Dremel Diamond bit on a flame bulb to use it with small LED light, but I got impatient and held the bulb too tight, plus put too much pressure on the blade. What worked was going really slow without putting pressure on the bulb; it came apart easily (I only needed the part above the metal). This is a fun idea.
Dec 17, 2008. 2:49 PMkorbinmiller says:
When i did it exploded
Dec 18, 2008. 3:43 PMbotronics says:
A little air space allows for expansion. Remember, a liquid is not compressible. The light bulb is weak enough without expanding liquid trying to break it.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
451
Author:ChrysN
I like sewing and crafts,and trying new things. I'm vegetarian and always looking for new recipes. My cat's name is Mirko and likes to be in the centre of things, so you will see him in several of m...
more »
