3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Light bulb snow globes
Step 8A few notes
A few notes
I had several failed attempts with this light bulb snow globe project. Mostly involving the glue. My first attempt was using a hot glue gun to attach the figurines and then seal the caps on the light bulb. I thought it worked, until I found Santa floating belly up a few days later.
-I have a low temperature glue gun, which may be the problem, also I don't think it glues well to smooth surfaces like glass.
-After the failure with the glue gun, I tried some silicone sealant, it works great for sealing the caps onto the light bulb, just make sure you leave enough time for it to cure.
-I also tried a "waterproof glue" I found in a department store, for attaching the figurines to the glass and cork. It works well (no floaters). A marine glue would probably do the job too.
Dismantling light bulb
Ideally, I wanted to use the base of the light bulb instead of the bottle caps, so that there was no doubt that the snow globes were made from light bulbs. Unfortunatly, I did not get a clean break when I took the light bulbs apart, so the neck would have gaps when I tried to put it back on the metal base. I know it can be done, the light bulb you see in step 2 worked nicely but then I had troubles with the glue (see previous note). I hope you have better luck than me.
Glycerine
I added the glycerine to the water so that the snow would fall more slowly. Another option could be to use mineral oil instead, but I wasn't sure if it would effect the glue.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
451
Author:ChrysN
I like sewing and crafts,and trying new things. I'm vegetarian and always looking for new recipes. My cat's name is Mirko and likes to be in the centre of things, so you will see him in several of m...
more »
