Light Controlled Window Lamp
842
7
Posted in TechnologyElectronics
Introduction: Light Controlled Window Lamp
Why do I i wan't light controlled light?
I build this be curse of I'm tired of change the timer every month.
So when the sun go's down the lamps light up.
plus it's look like some one is home be curse of it's light up diffrent time every day/ week.
What do I need?
5V controlled high voltage relay. HERE
Soil Humidity Sensor. HERE
Photoresistor. HERE
Cables. HERE
Step 1: Add the Relay
Start with opening the power switch and cut the wire inside ( only the one with contacts) .
connect the wire to the relay. One in the middle and one in right or left. left on mine.
Step 2: Setup and Connect Photoresistor
On the Soil Humidity Sensor you have a potentiometer to set the light density.
I put the photoresistor on a stick to put in the flower.
Step 3: Connect All Wiers
I use an China USB contact as power source for this. So I needed to get longer wires to power this.
I soldered the power cables from the Sensor and relay.
Connect the D0 from the sensor to the relay control pin.
And you are DONE!
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
