Light-weight Sturdy Backpacking Stove
 by DeltaS
Three-photo summary:
This stove is inexpensive, light weight, compact, and portable. Unlike the soda can variety (available all over the web), this stove is made from a discarded film development tank and extremely sturdy! (We snapped two drill bits while manufacturing this stove.)
Cost: $3 (commercial models: $15 to $150)
Weight: 4 oz, may reduce to < 3 oz with judicious cutting (commercial models: 3 oz to 30 oz)
Dimensions: 4.5 cm in height, 8.5 cm in diameter (fuel reservoir included)
Fuel Recommendation: 70%-90% rubbing alcohol
Energy Efficiency: 1/4 cup of 91% alcohol boils about 2 cups of water
Step 1: Find the right canister
Tools: band saw, ruler
We found a film development tank with a lid among a pile of lab supplies in the UW-Madison SWAP shop. With its 1-mm thick wall, it's sturdy all right! We just need to saw off the top. 4 cm from the bottom gives more room than we need to store the fuel for cooking. 2 cm would have done just fine and saved an extra ounce of weight -- it wouldn't have been safe to cut though.
4 cm tall: up to 1 cup of fuel
2 cm tall: up to 1/2 cup of fuel
SpyderTattoo says: Nov 25, 2010. 12:09 PM
What did you do to secure the two pieces together?
junits15 says: Dec 21, 2009. 4:38 PM
you have (what looks to me like) to many holes in the burner, 24 is always a good number to use
spark master says: Jul 15, 2009. 4:58 PM
hi, Was the top of the can a knob to pull off the lid? you make no mention of it. All the rest is nicely done, but you need a picture of the can lid BEFORE you hacked it up. You can add a nice chunk of baked off fiberglass wool inside , (sometimes or maybe always, there is a chemical on glass wool insulation so heating it up drives of the chemical smell , but burning it once twice probably does same thing). also drill the center hole and put in a rivit with a tapped center, you can add a screw that allows it to be used as a fill spout, and you could make a simmer ring for it as well. If I can find cans like that I will make one. I like the sturdier construction. The Gram Weenies are the types who snip their fingernail off before hiking to save weight. Real hardcore back backers take nothing extra if possible, this in nice to leave in the car or ruck sack with canned goods for when the stinky stove hits the whirley bird thing. The benefit of lighter stove is to bring a pot stand and a windscreen, a "stove" and your device is the "burner". bravo my friends, I love the picture with the fire extinguishers and the unit. sparkie
roppongi says: Mar 7, 2009. 1:56 AM
Is the "thin metal canister" one of those things for developing black and white film rolls?
kwkstar in reply to roppongiJul 9, 2009. 6:34 AM
I use to have a darkroom years ago, and after seeing this I went out to the shed and dug through some boxes. And found a ss film developing tank. It looks very similar. It sure looks like the fill and exit spout was ground off. Pic in step two!
whitedem0n says: May 29, 2008. 2:25 PM
anyone have other Instructables for hiking/camping I'd love to know
HAL 9000 in reply to whitedem0nFeb 18, 2009. 9:54 AM
There are TONS of those here, just do a search. also, if you want to build a stove zenstoves.net is a site with instructions to build about a hundred stoves, ranging from *very* simple to incredibly complex.
HAL 9000 in reply to HAL 9000Feb 18, 2009. 9:57 AM
Oh, yeah, i forgot, i have a group for this kind of stuff http://www.instructables.com/group/happycamp/
check it out
lasermaster3531 says: Jan 21, 2009. 1:34 PM
cool!
Sergeant Crayon says: Apr 21, 2008. 2:56 PM
This would be perfect for a moderate or beginner backpacker like me! How much do you think it weighs? I can see a lot of really intense backpackers (definitely not me) complaining about it's weight (Again, not me!). But I agree with you on the sturdy and long-lasting bit. Good job!
DeltaS (author) in reply to Sergeant CrayonApr 22, 2008. 10:56 AM
Since everyone is curious about the actual weight, I've included as much as I think people care to know on the intro page. Thanks for visiting!
Sergeant Crayon in reply to DeltaSApr 22, 2008. 2:53 PM
Cool, it sounds much lighter than I figured! I might just have to make one of these!
FunkLiberationFront says: Apr 21, 2008. 10:18 AM
You say it's "lightweight". Any idea what the actual weight is (with pan)? The reason most people make their own stoves is to shed weight. I made one out of a small size cat food can that I think weighs < 1 oz. Of course yours is undoubtedly sturdier and probably burns longer.
DeltaS (author) in reply to FunkLiberationFrontApr 22, 2008. 10:54 AM
Specs for this stove are up!
FunkLiberationFront in reply to DeltaSApr 22, 2008. 2:10 PM
Awesome, lighter than I would have suspected. You may also want to test this stove using denatured alcohol. That's what I use for my stoves. It might not burn quite as long, but burns cleaner.
gmoon says: Apr 22, 2008. 5:04 AM
That's pretty cool, reusing a developing tank. Although I'd still prefer the stainless steel tanks and reels over the plastic ones--if I worked with film anymore (ain't digital wonderful?)
But I hope you washed the crap outta that tank many times before cooking in it.... I wouldn't want to ingest any photo chemistry.
LinuxH4x0r says: Apr 21, 2008. 5:52 AM
great job! I had made these before, but most of them sucked. +1
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
