3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Lighter USB flash Drive
a fun half hour project that give a pleasing result.
you'll need:
An empty lighter (I used bic mini as I had a thumbdrive for this)
A large nail (brute force is needed at times)
A saw (hacksaw's good)
a dremel or sanding block etc (smoothing edges)
Step 1Knock the ends off
Knock the ends off
First take your saw and cut just on the line of the join between the body and the whit end cap, one this is cut off you may need pliers to pull bits of it out. Once the bottoms off you need a screwdriver or anything slim but strong enough the shove into the cavity and break the plastic bits of the inside off (creates more room)
After this pry off the metal part of the top and you'll see that the flint wheel is held between 2 plastic legs, push these apart to pop the wheel off and expose the flint tube, a spring and little stone like cylinder should have fallen out. Now take your nail and slide it all the way into the tube. Hit the nail with a hard blunt object, a hammer's good but not necessary. Shake out all the plastic that's now broken off.
81 comments
1-40 of 81next »
Aug 27, 2011. 9:35 PMneozelandes says:
just check my foto library
Aug 27, 2011. 9:31 PMneozelandes says:
i dont know how to add photo's to the comment
Aug 27, 2011. 9:26 PMneozelandes says:
i made one just like it then i put an icon on the drive so when i connect it to the computer it comes up like this
Mar 13, 2008. 4:30 AMNeonLime says:
My School Wont Allow Flash Drives, They Saw Mine And Said No No No Im Taking It Mine Now, Could Contain A Virus NOPE! But My Tech Teacher Said Its Ok In His Class :P
Oct 14, 2010. 3:34 PM8bitRaven says:
Why do you capitalise the start of every word?
Aug 12, 2010. 2:08 PMHycro says:
The high school I went to had a similar policy, though, the teachers let you get away with it, but if the principal or vice principals caught you...you lost your drive for the day...
Mar 27, 2008. 9:02 PMiamthemargerineman says:
woah. crazy. although i think i did see a create a virus to shut down your school's system instructable a while back. still crazy though. i'm too cheap to print at home... so i save stuff to my drive and print at school. i pay them enough money, gosh.
May 14, 2008. 9:46 AMlooking4ideas says:
You think thats ridiculous??? My school removed all the USB ports from the computers !!!!!!
Mar 14, 2008. 9:38 AMNeonLime says:
Agreed Lol. I Only Used It To Play Games :( (Im Allowed To Play Games :P) But Oh Well..
Mar 21, 2008. 6:12 PMXellers says:
Lucky! I'm allowed to have a flash drive, but there are no games allowed in my school. NO VIDEO GAMES PERIOD.
Dec 8, 2009. 7:39 PMandrew.kunk says:
wow i did the EXACT same thing just yesterday. SAME EXACT lighter just different usb.
they look idenrtical
Aug 15, 2008. 5:13 AMjo jo says:
I feel so poor I don't even Have a screwdriver in my house and I don't Have the money to buy one
Sep 14, 2008. 2:45 PMcry_wolf says:
The dollar store is your friend bud. Trust me, all my tools are from there. I have a hammer, screwdrivers, etc that i all purchased for a dollar each and they get the job done just fine. God bless. :)
Nov 5, 2008. 2:51 PMAnarchistAsian says:
yeah, dollar stores are so helpful in these dark times...
Jun 10, 2009. 2:34 PMthoraxe says:
or try the flea market, you can get good quality tools for a dollar there as well, got some good punches and cold chisels for $1 each
Jun 12, 2009. 6:07 PMAnarchistAsian says:
yeah, too bad there aren't any near where i live...
Aug 15, 2008. 7:18 PMJettyMae says:
you could always use a butter knife instead of a screwdriver. A butter knife is a poor mans screw driver. ~Ashley
Aug 17, 2008. 7:08 AMjo jo says:
thank you I'll probably use my brother's Zombie knife that he has in his computer case.
Apr 6, 2009. 1:25 AMdaniel.b says:
does the flash drive come out the end
Mar 16, 2009. 8:41 AMhabrrr says:
I made mine like this(sry for the bad pic)
Nov 5, 2008. 2:52 PMAnarchistAsian says:
oooohh, i've never seen this ible before, until that subscriiption thing... nice job
Jul 16, 2008. 11:47 AMRedgerr says:
well, i didnt know where to reply below... so ill do it here... hot glue is fine for hd's because they are often running at 115F. Heat is not a problem because they allways like heat, and too much cold is bad for them. im sorry to hear aobut your harddrive and i hope it works out again :) welp, have fun ~Redgerr BTW: Great instuctable :P
May 8, 2008. 1:25 PMFixedHDD says:
very good but i added something: you remember these bic lighters? theres is a smaller one an a larger one. i cut the larger one and make a cap out of this. So i can keep my usb thumb drive clean! and out of dust Greetz (sorry - i am german;-)
May 12, 2008. 7:55 AMFixedHDD says:
oh no! my USB drive crashed! I wanted to glue this in place because it was a bit loose. i had nothing but wooden glue! but i this this is better than hot glue i thought hot glue would destroy these chips because its hot. i glued and then i read the writings in the bottle: waterbased. oh dear.... but it doesn't matter.. i thought it could be broken after this. so i used a giveaway for this and i saved nothing important on this. And what do we learn? do not use waterbased glue, only use a stick where nothing important is saved, do not use your best USB drive,... Greetz.
Jul 7, 2008. 8:47 AMpowercamg4 says:
i did that too
May 12, 2008. 11:49 AMFixedHDD says:
yeah? not too hot? that's really interesting.... so I will learn from that mistake and will use hot glue instead of waterbased glue in the future.. but what am i going to do with my f***ed up USB drive? i let the glue dry and try after a week again Greets Justus
May 12, 2008. 1:23 PMFixedHDD says:
yeah of course. but I don't think this will work anymore. i plugged this already and found out that is not in a working condition. but the 5V from the USB port goes through that thing and killed it for sure....
May 13, 2008. 7:51 AMFixedHDD says:
that must be some fun! but I plugged this an nothing came. not even a sign "hardware detection failed" or so. the LED on my USB controller didn't light up. anyway....i will try this later. but then i will use hot glue!
May 16, 2008. 5:38 AMpunkatsub says:
Mine has a black spot, and it still works
Jul 1, 2008. 12:59 PMFixedHDD says:
Uahhh!!!
it works! I put this thing away because i thougt it was dead.
anyway. i was bored so i decided to check instr.com. i looked around and then i came here and i remember my broken USB-Drive. i think i will give it a try.
and it makes "ding dong" and that Drive was listed under my computer!
pretty nice that thing
Dec 6, 2007. 3:58 PMbikerguy7 says:
1 time accidentally brought a hammer on a plane omg lol
Feb 14, 2008. 11:52 PMTobita says:
i brought a 12 cm jackknife in the plane by accident in my carry-on, even worse i was going to Canada from Saudi Arabia O__O
1-40 of 81next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
197
Author:killerjackalope(My website)
A northern ireland based maker that likes breaking stuff as well as fixing it, of no fixed abode for now Working PR for a club in Belfast and freelance photography. I enjoy working with computers,...
more »
