Introduction: Lighting a Closet With Holiday Lights
Got any unused holiday light strings and a closet that doesn't have a built-in light (as is often the case in older homes)? Have too many shadows in your closet? Those LED push lights from the dollar store don't cut it? I'm showing a way I lit up a dark closet with unused light strings. I could do the same with LED light strings as described in another Instructable, but I wanted to use some spare light strings. Since the lights are only on sparingly, the amount of electricity used with LED or incandescent lights is negligible.
Step 1: Install Hooks (drive Rings)
The hardest part was to get special hooks to secure the lights in case I wanted to change or remove them. The hardware store is likely to carry plastic clip hooks for supporting cable, but I opted for drive rings (top ring in picture) so I can remove the lights for repair or replacement. A few places provide the rings online for low prices (another variety is the bridle ring, which can be screwed on). Hammering the 1/2" drive rings shook my closet jamb and I was worried about it separating from the wall, so I cut the rings down with a Dremel (bottom ring in picture) and pre-drilled holes on the jamb inside to push in 11 rings on the inside of the closet (3 across top and 4 on each side).
Step 2: Install Switch
I found this nifty plastic switch at the hardware store and installed it on the common side of the wires. The common wire in a three-wire string runs straight from the plug and only connects to 2 or 3 lights (three-wire strings use a combination of parallel and serial connections so one burned out light doesn't affect the whole string). The switch can be installed on either wire of a two-wire string (which are found on older lights), but I recommend getting a three-wire string so you rarely have to worry about replacing bulbs. The switch was fixed to the wall by driving a screw through the bottom plate (without touching connections) of the switch.
Step 3: Reinforcement From Hooks (drive Rings)
After wrapping the lights around the inside of jamb, I added extra protection from rubbing by the corner rings by covering the wire in short pieces of unshrunk heat-shrink tubing (sliced lengthwise and slipped over the wires); black electrical tape also works.
As a closet without an original light is unlikely to have an outlet, I put a hole in the wall and ran an extension cord (made from lamp wire and plugs) from the light string to an outside outlet. Now my wife and I appreciate having nicely-lit closets!
Step 4: View of Light From Within Closet
A view drive rings (or other holder you use) support the lights at the top of the door frame.
Step 5: Larger View of Installed Switch
Make sure lights are not plugged in when installing switch, and the cover attached before plugging in.
