Lightrider DIY Bike Light
 by Diyler
FeaturedContest Winner
Made a DIY version of the revolights http://www.revolights.com
total cost for one wheel is about 35 dollar
instead of a microcontroller i use simple reed magnet switches
the two outer rings consist of 18 Led's in 6 groups each all is powered by two AA batteries they are located on the hub
the only thing i don't have because i use the reed switches is the cool animation like revolights when the wheel stands still
Materials:
36x High Power 8mm Led's (18 on each side)
2x two meter long Aluminum stripes 15mm wide (in my case shortened to 1,75 meter)
6x Reed magnet Switch
2x 2meter 7 pin flat ribbon cable (one for each side)
2x 7 pin mini plugs (for easy installation)
Zip ties to mount the whole thing on the wheel
Soldering iron
Hot glue gun
Drill
1-40 of 49Next »
caniffis says: Jun 16, 2013. 3:32 PM
not sure if you have found your batteries yet, if not 23A 12v batteries are the ones to go for, very small and perfect for LED strips.
cepi85 says: Sep 24, 2012. 12:11 AM
cool video!!!!
Diyler (author) in reply to cepi85May 15, 2013. 3:13 AM
Adambowker98 says: Nov 1, 2012. 5:57 PM
Could you give some more instructions? This is super cool but I can't really tell how you made it.
Diyler (author) in reply to Adambowker98May 15, 2013. 3:12 AM
hey sorry for the late reply, right now i´m building a lightrider Version 2.0
it will be ready in a bout a month or so, then i post a new instructable which should be much simpler to build
Mr. Gadgets13 says: Jan 5, 2013. 1:54 PM
I think it's a great idea to use reed switches!
Diyler (author) in reply to Mr. Gadgets13May 15, 2013. 3:08 AM
hey thanks. yeah it´s simple and cheap thats why i´m use them.
haemophilic says: Apr 14, 2013. 2:53 PM
Hi, Good job you have here. I wonder whats the outcome of your smd led strips version? Hope to hear from you soon.
Diyler (author) in reply to haemophilicMay 15, 2013. 3:03 AM
hey sorry for the late reply, the led strip version is doing well, i hope in about a month it´s done.
right now i have the aluminum rings done and the led strips are glued to them, next step is soldering and searching for a compact 12 volt battery.
wobbler says: Oct 25, 2012. 5:56 PM
You have complicated the circuit diagram slightly. It's not necessary to show the wires from the reed switches rotating around to the LED groups. e.g. the white connection from the reed switch could go straight to the LEDs with the yellow LEDs. It's not actually necessary to offset the wiring with respect to the reed switch in reality, you can just position the magnet to a different angle relative to the hub and the LED lighting point should consequently move also.
I presume as you don't have an on-off switch that you leave the bike with the magnet in a dead zone to stop the batteries wearing down when you're not riding it?
Roshy10 in reply to wobblerApr 6, 2013. 6:55 AM
You are right, the circuit diagram is overly complicated, but it shows how it is laid out in real life, which is helpful when trying to build this yourself
Diyler (author) in reply to wobblerOct 26, 2012. 8:25 AM
yeah you are right it´s a little bit difficult but it´s only a prototype
the on off switch is on the battery case look close
right now i´m into building a much simpler version with smd led strips so it´s less soldering and simpler to install
and a really detailed instructable so anyone can build it
wobbler in reply to DiylerOct 26, 2012. 3:57 PM
No problem- Instructibles is all about prototypes and how they develop!
I would show the on-off switch in the circuit diagram also. Regarding SMD leds, you can find these cheaply in poundshop (or your equivalent) bike lights. You just have to use a sharp knife to cut though the chip connections and then wire straight to the LEDs.
Look forward to seeing your new improved mk2 version.
Diyler (author) in reply to wobblerMay 15, 2013. 3:07 AM
hey sorry for the late reply i´m not going to use sms leds alone. I will use led strips http://led-sa.co.za/wp-content/uploads/2011/05/20090917211852.jpg
jim_2000 says: Mar 15, 2013. 6:46 AM
I love it! I always thought the animation the revolights plays at stops would get annoying to drivers and cyclists.
Dranem says: Dec 13, 2012. 12:13 AM
Sie können über "http://www.instructables.com/id/Magnetic-Induction-Bike-Lights/", ein licht mit kein batterie sehen. Achtung! der rote led sind mit 1.7-2 V versorgt.
You can seen on http://www.instructables.com/id/Magnetic-Induction-Bike-Lights/, a light without baterie. Be carefull! Red LED are fed with 1.7-2V.
En tout cas, beau travail......
P.S. :
Here the way i use on my bike (in french, but lots of pics):
http://cyclurba.fr/velo/78/frein-dynamo-accu-led-velo-eclairage-energie-freinage-recuperer.html
lio34 says: Dec 7, 2012. 7:47 AM
Hy !
Some news about your much simpler version with smd led strips ?
Diyler (author) in reply to lio34Dec 7, 2012. 10:35 AM
i have so much to do right now but i think it will be done in about a month or so the aluminium rings are ready right now so its just a matter of days or weeks i think i will do theme in the christmas holidays
Chefke says: Dec 3, 2012. 11:01 AM
Any idea when the detailed instructable will be ready? This is truly awesome!
Diyler (author) in reply to ChefkeDec 7, 2012. 10:35 AM
tryrey says: Nov 21, 2012. 8:01 PM
Could you post a close up how you install the stripes in to the wheel, please?
Diyler (author) in reply to tryreyDec 7, 2012. 10:30 AM
i just used zip ties to mount the aluminium rings to the bikespokes
Roshy10 says: Nov 11, 2012. 10:09 AM
I would Just like to point out you have not used any resistor so you LED's will not last as long as the normaly would
Diyler (author) in reply to Roshy10Nov 11, 2012. 1:23 PM
i don't need a resistor because i'm using 3,2 Volt LED's and two AA batteries each 1,5 Volt so there is no problem
hsnopek says: Oct 31, 2012. 4:14 PM
Hi,
I plan to make your project exactly the same as you made it only using 3,7V (4,2) 14500 AA Li-Ion Battery instead of 2 x AA (1,5V).
Is it okay to use 8mm Led's or do I have to make some modifications?
Thank you!
Diyler (author) in reply to hsnopekOct 31, 2012. 6:16 PM
just be shure you dont burn the led's when you use to much voltage most led's are rated at 3,2 volt
and you can use any 8mm led's to the size doesn't matter
Athul Jayaram says: Oct 25, 2012. 1:33 AM
Can you please explain the 3rd picture(The reed magnet switch connection part)?
Athul Jayaram in reply to Athul JayaramOct 25, 2012. 1:39 AM
And what should be the size of the reed switches!whenowl head
Diyler (author) in reply to Athul JayaramOct 26, 2012. 8:15 AM
The Reed switches in this instructable are rated 230volt 6Ampere and are about 3cm long
next time i use this one http://www.pollin.de/shop/dt/ODU3OTE0OTk-/Haustechnik/Sicherheitstechnik/Alarmgeber/Reedkontakt_HAMLIN_59050_010.html
cause its plastic and not real glass
but you can use anyone that you like
вшашкин says: Oct 25, 2012. 5:06 AM
It's very cool
Diyler (author) in reply to вшашкинOct 26, 2012. 8:10 AM
Thanks
breumer says: Oct 25, 2012. 6:59 AM
dude that's cool!
Diyler (author) in reply to breumerOct 26, 2012. 8:10 AM
Thanks
Vergeltung says: Oct 25, 2012. 10:44 AM
Hallo, gibt es eigentlich auch so eine coole Seite auf deutsch? Ich verstehe die Sachen zwar, es wäre für mich aber weniger anstrengend.
Vergeltung(Warum dieser Name?)
Diyler (author) in reply to VergeltungOct 26, 2012. 8:10 AM
Ja ich glaub ich hab mal eine seite gefunden weiß aber nicht mehr wie die heißt aber im grunde genau das selbe wie hier und mit den anleitungen auf deutsch übersetzt
siklosi says: Jun 21, 2012. 12:49 AM
It would look better if you made it so that LED's are lit only in one position so that it looks like wheel is not moving :)
Orngrimm in reply to siklosiOct 25, 2012. 12:54 AM
Would be difficult due to the "low resolution" the few reed-switches provide.
If you want such an effect, you can adapt the idea presented here and go with one reed-switch for each led.
Good luck with wiring! ;)
jwestenberg says: Sep 22, 2012. 1:39 PM
I am so gonna make this!
Shalendar says: Jun 25, 2012. 10:22 AM
Could you post a close up picture of how the magnet is mounted?
Diyler (author) in reply to ShalendarJul 3, 2012. 12:28 AM
its just a metal strip mounted to the fork
it has to be a real strong magnet mine holds about 1,5 kg
1-40 of 49Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
