iImage Information
Use this easy step by step instruction on putting the parts together to build your own lightsaber unit. It requires no soldering, gluing or anything other than the following parts and everything is in the plumbing area of Home Depot: Pop-up Basin Drain (1), Drain extension tube with threads and slip nut (1), Slip nut and washer (1), 1 1/4" Disposal gasket (6), 1 1/4" Slip joint washer (6), Faucet hole cover (1).
Step 1Lightsaber Head - Blade length adjustment ring
iImage Information
Put aside the drain cap, rods and brackets on the Pop-up basin drain. You can use them for other projects, but you don???t need them here. Slide the washer from the slip nut and washer set onto the pop-up basin drain until it is against the ball valve.
I made one of these in my latest video. You can check it out here:
http://www.youtube.com/watch?v=u9EvjRsc58w
Thanks for the instructions! Love the site.
When I was a kid, we rolled the colored plastic sheets used to protect schoolbooks into blades, and taped them on the top of small maglites.
It wasn't solid enough for a "real" battle, but stiff enough to play around.
If we managed the tighteness right on the roll, we could even make the blades "pop up" with a flick of the wrist :)
If you want easy reference.... just watch the movies. When a jedi or sith goes down, their saber deactivates before hitting the ground. The arena battle in Revenge of the Sith is a good example of that. In Return, Vader force throws his at Luke in the throne room battle.
Star wars lightsabers a guide of weapons of the force
I have it its reall ycool it has specs of all good lightsabers.
http://i71.photobucket.com/albums/i155/Wonko2/Photo-0201.jpg
someone can kill other with that lightsaber???
