Lightwings: Fiber Optic Fairy Wings
 by the_gella
Featured
Add some glamour to your fairy costume using fiber optics.
This method for light up wings uses a simple circuit of LEDs and a battery to achieve a look a similar to EL wire, but thinner and almost invisible when not lit up. The lighting isn't as even as EL wire because it uses a single light source instead of glowing along its length, but it was an interesting and fun experiment.
It would be pretty easy to advance the project by hooking the LEDs up to a LilyPad to create blinking or fading light effects as well.
Step 1: Materials
Materials:
* Fairy wings (store bought or handmade), with any decoration removed from the middle/center of the wing frame
* Sparkle Fiber Optic Cable - a specialty fiber optic that lights up along the length of the cable, choose the kind with 6 strands. The amount will depend on how large your wings are: in this example I used ~4 ft.
* Sewable Coin Cell Battery Holder
* 3V CR2032 Coin Cell Battery
* (2) 5mm or 3mm LEDs - super brights work best for a dramatic effect
* Conductive Thread
* Needle and Cotton Thread
* Felt
* Hot Glue Gun & Glue
* Electrical Tape
* Masking Tape (optional)
* Scissors
* Pliers
* Pen/Pencil
* Velcro
* Cardboard/Posterboard
ninjanody says: May 24, 2011. 7:44 AM
lol. real nice instructable... i hope my girlfriend is not going to see this.. she is in love with fairy wings... she will force me to fix that for her.... :-)
the_gella (author) says: Nov 2, 2010. 4:58 PM
Here's my Halloween costume using this technique - I added a switch in there and ended up soldering the connections instead of conductive thread, but the fiberoptics method was the same. I also made a matching mask with the left over ends.
Phusilly says: Nov 2, 2010. 4:46 PM
This is a great tutorial! Makes me want to be a faery next year! Thanks for posting :-D
TinCan says: Oct 21, 2010. 11:44 AM
At Radio Shack you can buy a 3 AAA battery holder with built-in on / off switch for $1.99 and use rechargeable AAA cells. May be a bit bulkier but in the long run, more usable & rechargeable.
Skyriam says: Oct 21, 2010. 9:43 AM
Hey great ideas! Thanks for sharing. I can't get the special fiber optic you mention, is there any way to get normal fiber optic to light all the way? Thanks!
TinCan in reply to SkyriamOct 21, 2010. 11:41 AM
I called the link to wiedamark.com for the fiber optic cable and was able to order by phone a small amount. Their website has a $50 minimum, but by phone you can order as little as 1 foot + S&H
the_gella (author) in reply to TinCanOct 21, 2010. 11:43 AM
That's great news that you can order small quantities. Thanks for sharing that fact!
the_gella (author) in reply to SkyriamOct 21, 2010. 11:13 AM
If you are using normal fiber optic you can try sanding it a little bit along the length or scraping with an exacto knife or scissors, that should scuff up the surface enough to get some light. It won't be as bright as the specialty stuff, but I've had some ok results with that method, just make sure not to accidentally break the fiber optic by sanding/scraping too much.
katmajic says: Oct 21, 2010. 10:08 AM
How do we vote for you?
MrKazekage says: Oct 18, 2010. 6:23 PM
o very nicely done may i have an estimate of how much eveything cost? my friend would love this for her costume
the_gella (author) in reply to MrKazekageOct 18, 2010. 6:36 PM
The fiber optic I used was about $2.25 per foot, battery was $2.50, holder $1.25, and a 2 pack of LEDs was around $2.50. I had conductive thread and the wings on hand, but if you want a small sample of conductive thread you can get it for $5 at http://soft-circuit.com.
The total cost of materials to augment the wings should put you anywhere between $20-$40. (add in extra if you are buying your wings instead of making them).
MrKazekage in reply to the_gellaOct 19, 2010. 9:24 AM
well thank you very much ill get right on it haha i showed my mother this also so it looks like im making two one for my mother and best friend xD ill make the fairy wings and try a different method for angel wings it will look good with the feathers in my opinion. ill try and take a photo of the angel wings and show you thanks again ^-^
the_gella (author) in reply to MrKazekageOct 19, 2010. 11:29 AM
Awesome can't wait to see it : )
mkdieb says: Oct 18, 2010. 4:32 PM
Love it! how clever! The steps made it a cinch to follow!
Lynne Bruning says: Oct 18, 2010. 7:20 AM
Yeah for blinky bling fairy wings!
ChrysN says: Oct 17, 2010. 11:30 AM
So pretty!!
kenbob says: Oct 17, 2010. 10:20 AM
Nicely done instructable. good stuff!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
