Introduction: Lilliput USBlight
Picture of Lilliput USBlight
A mini USB Lamp......multi use......
Step 1: You Needed:
Picture of You Needed:
old mini lamp,a USB cable(male),hot glue,material for soldering,a power bank(new or diy for some type of uses)....
Step 2: How To.....
Picture of How To.....
Take out from the lamp the mini frontal part with leds and soldering two wires(red and black) on it.....
add a led to the red wire (in serial mode) for push down the voltage:the lamp use 4.5 volt,USB
have 5 volt output......or simply resistor.......
use the hot glue for maintain two parts together and give form.......finish........
Step 3: You Can.....also.....
Picture of You Can.....also.....
change the central led with a changing colors led,change others led with differents colors(blue,red,orange
green.....) for give a very good color of background if you use this lamp on the rear of your TV......
you can use a power bank for all usages you needed like camping,fishing,work......
Thank's to watch.......... !!
p mishra (author)2015-07-06
a nice one
alby21europa (author)p mishra2015-07-06
Tank you....... :)
joseph07 (author)2015-07-04
I need this! I have a broken flashlight (the battery holder broke) like that and I'm going to do this! Thanks for sharing!
alby21europa (author)joseph072015-07-04
Tank you.....you can see my others instructables....i have make others lamps...
About This Instructable
756views
24favorites
License:
Bio: le Libre choix de savoir et de le dire aux outres
More by alby21europa:NanoPowerbankBluetoothLapTopReuseBlueBreizh Bluetooth Boombox
Add instructable to:
