3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Lime Jello, Yeast and Carbon Paper Fuel Cell
Can Jello Brand Instant Gelatin replace coal fired power plants? Probably not but it can be used to build a demonstration microbial fuel cell from common materials. This is a fun classroom or rainy day project, tie multiple cells together and use the power to light an LED. You'll probably need a joule thief as well. Output voltage and current are a function of cell volume and carbon electrode size.
Here's how it works, we're going to mix a little Jello brand Instant Gelatin with some Fleischmann's Active Yeast and a few drops of plant food. Once that solidifies we're going to cut out some fun Jello squares (yes, they still jiggle) and, using the carbon paper as electrodes, we're going to tap the energy produced by the yeast to create electricity.
This is an innovative form of the popular single cell microbial fuel cell or MFC. The gelatin serves a variety of useful purposes, including MFC container, fuel source and electrolyte. The yeast will feed primarily off of the sugar in the gelatin mix while the gelatin seals out ambient oxygen.
As you can see we started off with about 500 mV which ain't bad for some Jello and yeast...
Now let's get started!
Step 1Bill of Materials
Bill of Materials
Not much to this one.
The hardest item to find, believe it or not, was actual old fashioned carbon paper. I ended up ordering over the net since I couldn't find it in my local stores. Make sure you get real carbon paper since that is used for the carbon electrode and will significantly impact the performance of your MFC.
You'll need some instant gelatin. You want the kind with sugar in it (or that you add sugar to). I used Jello brand Instant Gelatin in lime flavor for reasons which will become obvious. Any gelatin should do, including unflavored gelatin with a cup or so of sugar dissolved in it.
You'll need some yeast. I used Fleischmann's Active Dry yeast for no particular reason other than it was there.
A candy thermometer or some other good way, including judgement, to keep from putting the yeast until the water has cooled down to 100 degrees or so.
A container, I used a square glass one that was handy. It should be convenient for cutting squares out of.
If you have some handy a little Instant-Gro or Shultz's plant food adds useful supplements to the medium.
Now that we have everything let's make some Jello...
91 comments
1-40 of 91next »
Feb 19, 2012. 5:10 PMMFCHELPNOW!!!!!SCIENCE FAIR IN DAYS!!! says:
can i use carbon cloth instead of carbon paper? also, do you think this would suffice as a dumbed down version of a microbial fuel cell with containers as the anode and cathode, a salt bridge and the whole mile? SCIENCE FAIR IN 2 DAYS HELP PLEASE!!!!!!
Apr 18, 2012. 8:06 AMdstrater says:
(removed by author or community request)
Apr 29, 2012. 9:18 AMdstrater says:
We made our own carbon paper using plain white paper and bought some artist's carbon for drawing and just scribbled very thickly onto the paper. It worked! We got measurements of up to .22 mV. We are attempting it again today to see if we can get higher measurements.
I still can't figure out what the mediator is in this project that is actually making it work. I was wrong about the fluoride in the water, that would actually make it work less if it had any effect at all. NaF prevents glycolysis. We tried this with plain gelatin with sugar added too, calculating the measurements of sugar in green gelatin, and an approximation of about 4g per tsp of sugar, so we added 20g of sugar to 1 cup of clear gelatin. We got some slight readings out of the plain gelatin, but it was much lower than the green. (.01 and .04 mV compared to .22 and .21 mV). So clearly something in the green is making it function better.
The first time we did it, we also added too much yeast (thinking more yeast would produce more electricity), but it just got all puffy and didn't produce anything, probably processed all of the sugar before we even got to measuring it.
Nov 30, 2011. 10:10 PMsuy2 says:
what proportions did you use for this? i tried doing this but my gelatine gets all puffy as the yeast grows
Dec 4, 2011. 6:33 AMsuy2 says:
oh.. and uhm i tried making four units of gelatine battery which read 2V. i was trying to make a toy car function which only needs 1.5V to run but it won't function :|
Mar 2, 2011. 10:00 AMAaruni says:
Is there any way thro which the electricity produced can be showed as a function of the sugar remaining in the cell or alcohol produced?
Maybe, using a glucose sensor or an alcohol detector..
Also, can u tell me how can i make 1 of these (Could not find them on d instructibles site)
Dec 14, 2010. 6:35 PMcybergenius says:
hey, i'm planning to make this for my science fair.......
can you please tell me how long this cell will last?????
BTW the instructable was gr8!!!!!!!!!!!!!!
Nov 7, 2010. 4:15 AMnutsandbolts_64 says:
I made 300 mV out of a 1x1cm dry cell (yes, one). Not the dry cell AA battery, as in a cell from a dry pile. Nice MFC by the way. I should probably make one for reserve.
Oct 4, 2010. 11:36 AMwduck3 says:
Could you use non-carbon electrodes, such as aluminum foil or a copper sheet?
BTW great instructable. I'm a fan :)
Oct 5, 2010. 2:31 PMwduck3 says:
Thanks! I look forward to making one soon.
Apr 2, 2010. 10:08 PMUnit042 says:
(To the author if this Instructable) This is an amazingly simple and educational project here! The power output you achieved with mostly kitchen supplies is amazing.
From what I understand, the yeast eats the sugar and leaves electrons at the oxygen-lacking electrode, and the oxygen present electrode does its anode stuff.
There must be a way to contain the electrodes and 'electrolyte' so that Jello does not need to be used. Also, it would be advantageous to have this container shaped in such a fashion so as to encourage the addition of yeast-food; furthermore, a collection area for the dead yeast etc. gunk to pile up out of the way would go a long way toward MFC longevity.
Sugar powered LED's.... The combination of my two favorite substances...Mmmm....
Also, my younger brother has successfully made some wine with store-bought grape juice, sugar, and yeast. Oh, and time. About a month... or three? Anyway, do you think it would be possible to slap some electrodes on this and have it generate electricity as well as alcohol? But then again, there is oxygen present for the yeast to have...  if I have the anode deny the oxygen except through electrical reaction stuff, will the yeast's anaerobic consumption of glucose (sugar) then cease alcohol production?
Another side question: it is a commonly known fact that the yeast eventually produces enough alcohol to make the concentration of it lethal to themselves. I know that the alcohol is taken out by distilling (boiling alcohol out without boiling water out), but is it possible to remove the alcohol during the fermentation process without killing the yeast, so that yeast eats all the sugar present? Maybe hooking up a mild vacuum pump to lower the pressure to alcohol's evaporation point?
PS: Does it have to be "Fleischmann's Active Dry yeast " or will bread-machine yeast do?
Mar 24, 2010. 3:22 PMsmeezekitty says:
I have something that creates 1V but you use at your own risk.
Take a dead carbon zinc battery apart and take out the carbon rod and save the zinc case.
Fill a jar with water and add salt until its slightly white.
Hook wires up, one to the carbon rod, one to the zinc case.
Dip the electrodes in the jar.
To recharge, connect to 6-12v ! and it will restore its state to 1V.
Mar 24, 2010. 3:27 PMsmeezekitty says:
Should have mentioned, when charged, it can run a small electric motor for up to 45 seconds.
Mar 23, 2010. 12:20 PMEvilgenusi124 says:
Alright. Finally got my carbon paper, just let the mix set , and I added the cathode/anode. I attached my joule thief to no avail. I'm not sure if it is putting off voltage, because I used unflavored gelatin.
Jan 15, 2010. 4:48 AMmeekah says:
 i would just like to ask if there are any more possible media in which the yeast could be held into. and if the amount of yeast  and sugar could make a difference in the power generated. ty:)
Mar 10, 2010. 11:29 PMhubert_huzzah says:
Agar (the slime off seaweed) forms the basis for most nutrient media. It also forms the basis for Jelly (what you call "Jello"). What you mix into the media really depends on what you intend to grow.
For making Agar nutrient media buy some vegetarian gelatin (this is not an animal rights thing, it's just that real gelatin is not quite as good for yeast - despite the fact that the Bacto-Peptone is made from roughly the same things).
Use the vegetarian gelatine in the following recipes:
A better broth for yeast is the following
Yeast Broth
Yeast extract 5g  (Marmite works - if it calls itself yeast extract and you can find out that it is "autolysed yeast extract" - then it is a substititute).
Bacto-peptone 10g (This is usually produced from pulped and boiled animal bones. Realistically, you could substitute well strained, very reduced, bone stock for the distilled water).
Glucose 10g (you can buy from a brewing supply shop)
Distilled water 500ml
Mix ingredients well. Autoclave for twenty minutes (alternatively, get a pressure cooker, place the mixture in a strong glass casserole dish and pressure cook for twenty minutes). This nutrient mixture can then be used to add into Jelly as a nutrient.
For example. Make yeast broth, Add 10g vegetarian gelatin. Autoclave for 20 minutes.
There are literally hundreds of recipes for media and this broth is just a simple one. The other substitute for Jello is cargeenan, which is - again - produced from seaweed.
Part of the choice of nutrient broth depends on the type of yeast chosen. Bottom brewing yeast is significantly different from top brewing yeast in what it likes.
Jan 22, 2010. 10:43 AMCoolKoon says:
I doubt that any kind of playdough (even the inedible one) could be inorganic.....
The idea of yeast making electricity is kinda neat, but it works only until the yeast has enough food to be alive and the whole thing is spoiled quite fast I'm afraid.....
Jan 23, 2010. 12:37 PMCoolKoon says:
This sounds interesting and stuff, but how long would a given unit of sewage give out that power? As I presume it won't have a "desirable" (flat) discharge rate, would it? Actually the thing is it wouldn't be anything new, just a special form of battery constructed from novelty parts/elements. This would be the first question electricity companies would ask anyway. Because if it's unreliable, they won't let it near their precious "grid". This is why they're very reluctant about wind turbines too, as they ask "what if/when the wind stops blowing? Who are we going to disconnect due to power deficiency"?
The idea is neat BTW and it reminds me of the "lemon battery" princible, though here the gelatine with the yeast seems to play a double role: an electrolyte and an electrode.
Jan 24, 2010. 1:45 PMCoolKoon says:
Interesting, I haven't seen the other carbon paper. But still. The electrolyte might be the gelatine itself (or the citric acid that is probably added in excess to lime-flavored JellO) and the yeast might be just a plain catalyst. Actually that's just a wild guess of mine as I don't know much about such complex organic reactions (my knowledge of chemistry is somewhat limited due to the fact that I'm not a chemist :P).
Feb 9, 2010. 5:41 AMEvilgenusi124 says:
*Evil Laugh* I'm gonna hook this up to a joule thief and see if that does anything
:D
Feb 1, 2010. 5:32 AMEvilgenusi124 says:
Could you use a carbon air filter? Such as one with layers that are separate?
Feb 1, 2010. 6:30 PMEvilgenusi124 says:
I attempted to test it, but how to I attach the wire to the carbon filter? Tape possibly?
Jan 25, 2010. 6:26 AMmeekah says:
i was trying a couple of variations and noticed something. is there a possibility that the effect of added nutrients (sugar) would not necessarily mean a higher voltage reading but a longer shelf life for the mfc because the yeast would thrive longer?
Jan 17, 2010. 4:44 AMmeekah says:
 would you think a rice flour and water mixture could be used as a medium? rice flour  and water cooked until it could be molded and set like gelatin?
1-40 of 91next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
155
Author:egbertfitzwilly(More about me at LinkedIn....)
