Step 2Notch Cutting 101
1.) Measure in from the end of the stick one stick width (in my case, 3/8") and draw a vertical line.
2.) Measure 1/4 of the width of the stick (3/32") in from the side of the stick on each side.
3.) Make sure that the width of each cut is the same as the thickness of the craft sticks (1/12"). In my case, I was lucky enough to have a jigsaw blade that was exactly 1/12". Hoorah!
4.) If you make any other notches, be sure to repeat steps 2 & 3.
Note: The dimensions of each craft stick vary from stick to stick. You may want to filter out some of the "undesirables" before you start cutting.
comment
Add Comment
abehambino
says:
Add Comment
