Remove these ads by
Signing UpStep 1: Gather Your Supplies
1) Two peices of birch verneer plywood or like matterial at a thickness of 3/4" ,length of about 18", and width of 3".
2) Two lag bolts that are at least 3 1/2" long and 1/4" diameter with 8 washers that fit onto them.
3) I used a a Japaneese pull saw and a combination suqare to make straight lines and cuts.
4) Before I intalled it I gave it a coat of Tung oil to keep it safe from splashing water, feel free to leave it untreated but some kind of finish will accent the cool endgrain of the plywood.
Visit Our Store »
Go Pro Today »
To critical commentors: Instructables is all about sharing ideas that inspire, putting thoughts together to come up with brilliant solutions. There are many ways to improve things for your own personal use. If you're worried about your knives falling out of the sides than put the bolts at the ends of the wood and make one pocket in the middle. Though the design, as is, may be done so that you can easily remove and replace the knives. If you're worried about the washers dulling the blades replace them with plastic or wood spacers like some of the helpful suggestions below.
And what about the sides? The knives could fall out if placed outside the lag bolts, falling behind whatever counter, stove, what-have-you you've mounted this above.
I like the simplicity, but it seems this could use a couple of revisions before prime time.
