Line Follower Arduino Robot With Object Avoid
767
Posted in TechnologyArduino
Introduction: Line Follower Arduino Robot With Object Avoid
About: GUYS FOLLOW US AT OUR FB PAGE ..DO LIKE ND SHARE ..OUR YOUTUBE CHANNEL IS S_R TRONICS...WATCH..TRY..INNOVATE..TASTE THE SUCCESS..THANK U..
hello guys...
this is our 5th project...its called line follwer robot with object avoid using ultrasonic distance sensor...
soo..when robot will move along black track this time if any object is infront to this robot..then the robot will be stop...after remove the object from the black line,the robot can move to this black line...
black line tracked will be performed by two ir sensors and for object avoid ultrasonic sensor is used...
sooo lets start..................
Step 1: Components
Step 2: Ir Sensors Connection
so
we have two ir sensors module...
left ir sensor and right ir sensor which have vcc,gnd and op..
vcc is connect to +5v
gnd is connect to gnd
op connect to pin of arduino
Step 3: If You Used As L293d Ic
if you use l293d ic instead of l293d motor driver..
even its will be easy for connection....
l293d ic have 16pin... 1,8,9 and 16 pin connect to +5v.
and 4,5,12,13 pin connect to gnd...
input 1,2,3 and 4pin is connect to arduino pin..
output is connect to left motor and right motor..
input 1 and 2 is connect for left motor..
and input 3 and 4 is connect for right motor..
Step 4: Circuit Diagram
here..........
two ir sensors are connect 9pin and 12pin in arduino..
left ir sensor:-output is connect to 9pin of arduino
right ir sensor:-output is connect to 12pin of arduino..
for ultrasonic distance sensor :-
trig is connect to 5pin of arduino
and echo is connect to 6pin of arduino....
l293d motor driver:-
8,7,4,and 3 pin of arduino are connect to the motor driver.
8pin of arduino connect 2pin of l293d
7pin of arduino connect to 7pin of l293d
4pin of arduino connect to 10pin of l293d
3pin of arduino connect to 15pin of l293d
and vcc is connect to +5v and gnd is connect gnd.
power supply will be from battery 9v or power bank..
Step 5: Uploading the Code
#include
int x,y,t1=0,t2=0; unsigned int D;
NewPing sonar(5,6,15);
void setup() {
pinMode(9,INPUT); pinMode(12,INPUT); pinMode(8,OUTPUT); pinMode(4,OUTPUT); pinMode(7,OUTPUT); pinMode(3,OUTPUT); }
void loop() {
D=sonar.ping(); x=digitalRead(9); y=digitalRead(12);
if((x==1)&&(y==1)) { digitalWrite(8,HIGH); digitalWrite(4,HIGH); digitalWrite(7,LOW); digitalWrite(3,LOW); t1=0; t2=0; } else if((x==1)&&(y==0)) { if(t1>=20) { digitalWrite(8,LOW); digitalWrite(4,LOW); digitalWrite(7,HIGH); digitalWrite(3,HIGH); delay(500); digitalWrite(8,HIGH); digitalWrite(4,LOW); digitalWrite(7,LOW); digitalWrite(3,LOW); delay(1000); } else { digitalWrite(8,HIGH); digitalWrite(4,LOW); digitalWrite(7,LOW); digitalWrite(3,LOW); delay(500); t1+=1; } } else if((x==0)&&(y==1)) { if(t2>=20) { digitalWrite(8,LOW); digitalWrite(4,LOW); digitalWrite(7,HIGH); digitalWrite(3,HIGH); delay(500); digitalWrite(8,LOW); digitalWrite(4,HIGH); digitalWrite(7,LOW); digitalWrite(3,LOW); delay(1000); } else { digitalWrite(8,LOW); digitalWrite(4,HIGH); digitalWrite(7,LOW); digitalWrite(3,LOW); delay(500); t2+=1; } } else if((x==0)&&(y==0)) { digitalWrite(8,HIGH); digitalWrite(4,HIGH); digitalWrite(7,LOW); digitalWrite(3,LOW); t1=0; t2=0; }
if(D!=0) { digitalWrite(8,LOW); digitalWrite(4,LOW); digitalWrite(7,LOW); digitalWrite(3,LOW); delay(1000); } }
soooo...copy the code and paste in arduino..
lets start how playing this robot..
Step 6: Result
here....
this video link will be help you to make this project....
sooo follow our channel s_r tronics..thats help to build project...
so subscribe our channel to stay tuned with us...and gets new project also..
try to like and do comment in inbox...
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    3 Comments
    program of line following robot with ultrasonic range finder using arduino uno
    Hey there!
    This is a nice little project and I really appreciate the effort you put in. At the same time I wish, that you would explain the principles behind your work. Like your other instructions it is more a "how to connect all parts", which is great if someone just wants to replicate. But you could teach the people so much better if you would explain how and why you did the things. Help others to become as smart as you are! (maybe you know the phrase "give someone a fish and he has food for one day - show him how to fishing and he will have food forever")
    Otherwise great work!
