Line Follower Robot Using Arduino
1,287
9
6
Posted
Introduction: Line Follower Robot Using Arduino
let's make a line follower ;
guys just follow the index and at last you will have your own line follower robot.
INDEX:
  1. INTRODUCTION
  2. COMPONENTS
  3. WORKING PRINCIPLE
  4. BLOCK DIAGRAM
  5. PROGRAMMING ON ARDUINO
  6. ADVANTAGES ,DISADVANTAGES AND APPLICATIONS
  7. SPECIAL DISCUSSION FOR T-POINT
  8. FOR ANY HELP CONTACT ....
Step 1: INTRODUCTION
A robot is a machine capable of carrying out a complex series of actions automatically,especially one programmable by a computer.A robot is programmed based on the requirement.for a line follower robot we programme the robot according to the line or track,keeping in mind of T point ,most line follower faces dificulties at T points.
Line following Robot is a machine that can follow a path.The path can be visible like a black line on a white surface or it can be invisible like a magnetic field.
Sensing a line and maneuvering the robot to stay on track,while constantly correcting wrong moves using feedback mechanism forms a simple yet effective closed loop system.
Step 2: COMPONENTS
Step 3: WORKING PRINCIPLE
Step 4: BLOCK DIAGRAM
Step 5: PROGRAMMING ON ARDUINO
Here two programme is given we can use any of these two based on our application.
PROGRAMME 1:
PROGRAMME 2:
void setup()
Serial.begin(9600);
pinMode(8,OUTPUT);
pinMode(9,OUTPUT);
pinMode(11,OUTPUT);
pinMode(12,OUTPUT);
void loop()
int a= analogRead(A0);
int b=analogRead(A1);
if (a>500 && b>500)
digitalWrite(8,1);
digitalWrite(9,0);
digitalWrite(11,1);
digitalWrite(12,0);
else if (a>500 && b<500)
digitalWrite(8,1);
digitalWrite(9,0);
digitalWrite(11,0);
digitalWrite(12,1);
else if (a<500 && b>500)
digitalWrite(8,0);
digitalWrite(9,1);
digitalWrite(11,1);
digitalWrite(12,0);
else
digitalWrite(8,0);
digitalWrite(9,0);
digitalWrite(11,0);
digitalWrite(12,0);
Step 6: ADVANTAGES,DISADVANTAGES AND APPLICATIONS
Step 7: SPECIAL DISCUSSION FOR T-POINT
USE INCRIMENTATION AND DECREMENTATION TECHNIQUES.
Step 8: FOR Any Help Write in Comment Section or Contact Me :shubham2ece@gmail.com
shubham kumar
shubham2ece
UIET,Punjab University
https://in.linkedin.com/in/shubham-kumar-746b84108
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
6 Comments
can I use a shield instead?
Hi,
i have tried it so far, but nothing until now. i have only changed the numbers. I have send you a pic of how my robot is connected so far. I have four sensors on my robot but am trying to make two work first. In order for me to take it to the next level.
Could you help me out?
hi,
I have been searching for days now for a code that works with my line robot but i haven't got true as yet. I hope that this code works with mines. I copied it and paste it into my arduino so far.
I only had to change the code to the pins that i used. But i am still afraid that its not going to work.
Is it possible to contact you if it does not function?
It will work.if doesn't you can contact me.
Nice instructable , thanks for sharing
