Line Follower Robot Using WitBlox
Published
Introduction: Line Follower Robot Using WitBlox
About: A maker and innovator
Building a Robot has always thrilled us. Building an Intelligent Robot that can take its own decision is even more thrilling. Let’s build a Line Follower Robot today using WitBlox. Line follower is an autonomous robot which follows either black line in white are or white line in black area. Robot must be able to detect particular line and keep following it.
Step 1: Step 1 - Get Ready With the Blocks to Be Used for This Project. You Would Be Needing a Battery, Power, Motor Driver and IR Sensing Modules
Step 2: ​Step 2 - Now Place All These Modules in the Order As Shown. We Are Using Power Block, IR Sensor Block As Input and Driver With Motors As Output.
Step 3: Step 3 - Next, You Need to Arrange All These Blocks on Your Model. Be Careful While Placing the IR Sensors at the Front As They Need to Be at an Optimum Distance From the Ground and Not Touching It.
Step 4 - Time to get your robot moving on the ground. You can use normal black insulation tape as the line for your line follower. Switch the power module on and experience the journey through the line with your robot. To see it working, log on to our YouTube channel.
Hope you had fun building the Line Follower Robot. In the next project, we shall make our robot a bit more intelligent by sensing obstacles and avoiding them.
Don't have WitBlox Kit. You can get it here or buy the Line Follower Robot from their site
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Microcontroller Contest
